Trim clips suck
Started to install new trim on my entertainment center project and the new cab trim came with new clips. These things are terrible, not the same size and shape of original. I bought the trim from classic parts of America. Has anybody had good luck with aftermarket?
![]() Join Date: Aug 2009
Re: Trim clips suck
Nice!!
I'll come get it & see if I have better luck |
Re: Trim clips suck
Please tell me that the TV lowers down into the bed when its not on!!! Awesome project either way!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Trim clips suck
I don't know about the clips. But that is a cool entertainment center.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: Trim clips suck
What I've found is the spring legs on the clips are in alignment to each other so they won't push past each other. I take some pliers and bend the springs so they are barely to the side of each other then when you push them in the holes they spring like they're suppose to.
By the way nice entertainment center. |
Post Whore
![]() Join Date: Mar 2013
Re: Trim clips suck
Can't help much with the clips, but I like that entertainment center!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Re: Trim clips suck
The narrow trim strip on the cab originally had clips with threaded studs. These holes are larger than holes in doors and bedsides so the spring clips won't work. I started to cut out small square pieces of sheet metal and tack weld 12-24 studs on when I fell onto a solution. While digging through a misc drawer for small nuts and such I saw some spare door panel clips I had for my 96 Silverado. Just so happens that if you pop off the retainer a 12-24 but will thread right up. I sawed off the top section of the clip to leave on
ly the D/D shaped head which slides right in the trim. |
![]() Join Date: Aug 2008
Re: Trim clips suck
I got the original type at an auto paint supply store.
