Old 10-15-2003, 08:35 AM   #1
VTKidder
71-72 cab lights
I've heard (CPNE) that the U01 option factory marker clearance lights were different through the years, and that 71-72 shared a style that was rounded, not like the teardrop in earlier years. I was wondering if these are a collectable item, or something in demand? The roofline on the 71-72's had (5) raised spots where the lights mounted to, so you just can't use any standard cab light. I have a set of (5) in overall good shape, and am just wondering it they're worth doing anything with. They look like the below.
If they do break or get lost somehow on a truck that came with them, what options are there for replacement? Thanks...
-adam
VTKidder is offline   Reply With Quote
Old 10-15-2003, 10:09 AM   #2
barn9
Half a bubble off!
barn9's Avatar
They are readily available new, but someone might want the ones you have for spares.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 10-15-2003, 09:28 PM   #3
Rod
Available but not correct script on the lens... federal Mogul part number 1313A
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-16-2003, 02:51 AM   #4
1969 GMC
1969 GMC's Avatar
I wondered about this too when I first got my truck. I think that they started making the cab bumps in '69 (thats what I have, if you couldn't tell :p ). I believe in '67 and '68, they used the chrome teardrop screw on variety. The lenses aren't really rare, because they didn't just use them on 69-72. They used the same clearance lamps til '87 (for reg cab pickups, '91 for burbs and crew cabs). They were also used on medium trucks in both time periods, but I do not know for sure about heavies. If you need a set, just go to the junkyard. I went and found probably 5 (73-87) C/10's with them, and 10 or more (73-91) C/30's with them. Alot had broken or cracked by the screws, but I found one truck with what looked like 3 brand new lenses, so I nabbed them for my GMC (It had a mismatched set before, 2 of this style and 3 of the hockey puck style, not sure what those are from). Hope this helps. Oh, and yes, my lights are listed on my option sticker, 3UO1AA.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-16-2003, 10:18 PM   #5
Rod
Heres a pic of the cab light teardrop style not quite like the originals but real close.
