90-93 Bucket seats and console ???
94 EXTENDED CAB 64 CHEVELLE |
Old member
They want bolt right up that I do know. They sit great but I'm only 5-9. I took a set of the 60/40 out of mine a few years ago and installed 99 Tahoe seats in it. I loved the 90 model seat though. One are the other outside holes will match up to the floor you just have to decide which one you want to use. Front are back.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: 90-93 Bucket seats and console ???
Ok thanks
Set them in your truck and sit on them. See if you like how they feel. If you like them, bolt em down.
If not, take the frames off, use wood blocks to see what height feels best, and then have the frames cut to that size |
thanks good idea !
Old member
Need to get the seat belts to match them. The shoulder harness ones will fit nicely into the truck. The threads are already in the cab side panel for them.
Just to be correct here the seats are 88-89 and the console looks to be late square or Suburban[maybe 86-87 truck 86-90 Sub]. Just decide how much of the stand needs to come off and burn some metal
looks good ! could u have mounted the seat flat on the floor ? i'm a big guy 6'4 350+# need all the room i can gat lol
thanks 4 the info..
