02-02-2017, 12:58 AM | #1 |
Where to purchase correct fitting A/C heater core
Finally going through the heater and A/C on my 72 and have not been able to find a heater core that has the pipes in the correct location. I have a new copper which I think is mexican production and the pipes are WAY off. I was able to manipulate them a bit but still more than an inch out of place. I took my box to the local flaps and still way off.
Other than NOS is there a quality core available these days? |
02-02-2017, 01:24 AM | #2 |
Re: Where to purchase correct fitting A/C heater core
I just installed one that I ordered and got from Rock Auto for my 1969 c10 with air.
More Information for APDI/PRO 9010121 Point to Zoom All Pro heater cores are designed to meet or exceed OE specifications for form, fitment, and function. Each heater model is tested in the actual vehicle HVAC heater module to ensure easy installation and proper function. All heater cores are leak checked several times throughout the manufacturing process to ensure a 100% leak free unit. Construction V-Cell Core Depth 2" Core Height 9 1/4" Core Width 6 3/8" Inlet Connection 5/8" Outlet Connection 3/4" Alternate/OEM Part Number(s): 3025322 APDI/PRO*Warranty Information 12 months Warranty Details |
02-02-2017, 02:25 PM | #3 |
None of the new reproduction heater cores fit like original Harrison heater cores. Every one that I've installed I had to bend the tubes some. To have fit without any bending you need to have an original recored. That's what I've done a couple times for customers and they fit like a glove.
02-02-2017, 02:35 PM | #4 |
I took the new core, unsoldered the pipes, and put the old pipe on the new core.
02-22-2017, 03:48 PM | #5 | |
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
