Old 02-02-2017, 07:37 AM   #1
dads71bigblock
Hooking up speedo on 65 after 700r4 swap
Hi guys, just bought a 65 with 700r4 in it with original speedometer what is cheapest route to get speedo operable?
dads71bigblock is offline   Reply With Quote
Old 02-02-2017, 09:30 AM   #2
verdell
verdell's Avatar
Re: Hooking up speedo on 65 after 700r4 swap
Does the original speedometer work? If so, I would just buy an over the counter speedo cable and hook it up. If the speedometer is very inaccurate then you'd need to replace the drive gear and/or driven gear in the transmission. These are color coded with a specific tooth count. I just went through this with my 700R4 and Dolphin gauges. This may help:
https://www.transmissioncenter.com/s...4-driven-gear/
verdell is offline   Reply With Quote
Old 02-02-2017, 10:59 AM   #3
dads71bigblock
I dont know if the speedo works or not, a buddy said 700r4 sent out a elec. Signal and did not have a cable style hookup?
Old 02-02-2017, 11:32 AM   #4
jchav62
1962 C-10
jchav62's Avatar
700r4's usually have a regular speedo cable hookup. Later 4L60E's are electronic.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-02-2017, 12:08 PM   #5
verdell
verdell's Avatar
If you have a 700r4 then it's just a matter getting a $15.00 speedo cable, hooking it up and seeing what happens. As jchav62 said, 4L60E's are electronic but you should be good with the 700R4. I just did the same with mine back in October but I had to get the correct drive/driven gears in order for the speedometer to read accurately.
Old 02-03-2017, 12:30 PM   #6
Moarplease
Easy as stated. Hopefully the drive gear is a workable color and you only need to replace the driven gear like I did. GPS speedo app on the smartphone is handy to calculate how far it is off once working.
Adam
Moarplease is offline   Reply With Quote
Old 02-03-2017, 03:38 PM   #7
blown240
blown240's Avatar
I have a 700r and it has an electronic sender for the speedo. Not sure what year they changed. I dont have it hooked up....
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
