Old 02-02-2017, 09:32 PM   #1
dracko
dracko's Avatar
Radiator Support bushings
Hey guys, I'm just doing some mock up on my '64, after rust repair to the cab, doors and fenders. Doors line up nice but the rad support seems to be sitting high and messing with fender/door gaps.
Wondering if this is the proper way the bushings go under the rad support? (I know they're old and gnarly but I figured since I didn't do the cab bushings things would go back into place how they were)
dracko is offline   Reply With Quote
Old 02-02-2017, 11:56 PM   #2
jtrichard
Re: Radiator Support bushings
those look good (BUT You may have the steel and rubber reversed) sounds like you need to shim the front cab mounts
jtrichard is offline   Reply With Quote
Old 02-03-2017, 12:16 AM   #3
dracko
dracko's Avatar
Okay thanks for clearing that up for me. Never considered shimming up the cab at the front. Would that also change how the rear of the cab lines up with the box?
Think it'd be harmful to remove the thick steel washers all together? That might bring the front down enough. .
Old 02-03-2017, 01:33 AM   #4
Captainfab
60-66 Nut
I'm pretty sure there should not be a thick washer on top of the frame bracket.
Old 02-03-2017, 02:13 AM   #5
62stepside longbox
62stepside longbox's Avatar
mine didn't have a washer sitting on top of the frame, it was just the bushing
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-03-2017, 07:59 AM   #6
dracko
dracko's Avatar
Well that's good to hear, knew I should've taken some pics before removing it. Thanks!
Old 02-03-2017, 08:58 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
http://67-72chevytrucks.com/vboard/s...82&postcount=6
Old 02-03-2017, 11:05 AM   #8
jtrichard
Here is the full thread that Rocknrod referred to http://67-72chevytrucks.com/vboard/s...82#post5818882
Old 02-03-2017, 03:25 PM   #9
The Rocknrod
Moderator
I knew I had the instructions to the kit I bought:
Old 02-03-2017, 10:21 PM   #10
dracko
dracko's Avatar
Thank man, looks like I have it set up correctly except for the bottom washer.
Maybe I am gong to need to shim the cab
Old 02-04-2017, 01:04 PM   #11
dracko
dracko's Avatar
I'm gonna replace the cab mounts and see if that fixes this. They're 50 years old anyways.
Old 03-23-2022, 08:57 PM   #12
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
I have the brackets that have a thick rubber on them. Can I replace them with the bracket that doesn't have a rubber on it?
Sick5 is offline   Reply With Quote
Old 03-23-2022, 10:08 PM   #13
The Rocknrod
Moderator
I've not seen ones like that so what do they look like?
Old 03-31-2022, 11:02 AM   #14
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
It still takes the above material but it has an extra hard rubber between the bracket and the frame. ill take a picture tonight.
