Computer in the cab?
Anybody else run their computers inside the cab? I think these mounts will work? Anybody have experience with this? Am I too close to the radio? Am open to suggestions?
Thanks... |
Post Whore
![]() ![]() Join Date: May 2015
Re: Computer in the cab?
Got mine behind the glovebox...but never again..from now on mine will go behind or under the seat
I welded a bracket to my brake pedal assembly. Clears everything with ease and i don't forsee a problem yet. Only reason I didn't put it under the seat was that I didn't want to extend all the wires. Each wire was cut and shortened tho
My 68 Build http://67-72chevytrucks.com/vboard/s...=1#post7272324 Herb! My C30 build http://67-72chevytrucks.com/vboard/s...80#post7304180 |
#4 | |
Have you had issues in the glovebox? What was the issue? Now is the time to move mine if needed.... Thanks!! |
Post Whore
Not in the glove box...behind it..mine has factory air and trying to route the harness and squeeze the comp and fuse block in was a nightmare..plus I've got very large hands so that made it even worse..when in bought my harness they even suggested a longer one but I thought there was plenty of room under dash..from now on I will just run the harness down the back of the engine and under the floorboard and do all my wiring under or behind seat mainly because of room..I'm working on my 53 now that has even less roon behind dash than my 81 does..
Post Whore
As for the radio.my comp and fuse block is about a foot or so from the radio and I havnt had any issues
Post Whore
Looks like you got a bunch more room under dash than I did...you might be alright where you've got it..
I mounted my computer up underneath the glovebox. Ran the harness behind the heater core and the computer is being held up by a metal strap. The metal strap is mounted at the firewall and on the back side of the glovebox door support.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 ![]() |
I put mine behind the seat.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
#10 | |
Can't really move it to the right, the unfilled mount you see is for the fuses and relays for the engine harness. That's also why I have the large hole thru the firewall. And of course, I'm running Vintage Air, so the passenger under dash area is getting pretty crowded. I like the one mounted to the brake box. I guess I could move it over there, but then it's close to the body harness and I don't really think my harness is long enough. Hate to start cutting wires on a new harness. I appreciate the input from everybody, guess I've a decision to make. Thanks!!! |
Senior Moment
![]() Join Date: Mar 2002
If you are thinking about something like vintage air it will be in the way. I ordered my harness from Hot Rod Harnesses in LA. They made it longer to go under my seat. I welded a half pipe on the high hump ((went with the with T56 6 Speed)'to hold the thick wiring harness then came up underneath the seat. Totally invisible and works Great. If your NOT running AC you have the room. Looks Very Nice
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#12 | |
Everybody's input is much appreciated. I'm going to leave it where it is. If I've got an RF problem down the road, I'll handle it then. I do enjoy seeing where everybody else put theirs! Lots of good ideas and nice work by all! |
#13 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Mine is under the hood on ds of radiator.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#14 |
I have never heard of anyone having RF interference with the ECM being too close to the radio, so as long as your radio fits with them mounted there I would think you'd be fine.
Do you have a build thread on your truck, or more pics? Looks like its going to be nice.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#15 |
RCA's can get interference but you usually need them right next to a power wire for a pretty long run. I have a set of shielded RCA cables that I've used in multiple vehicles next to power wires and other RF noise producing things and I haven't had any issues. If you want some insurance now to prevent taking stuff apart later pick up a set.
The antennae is already shielded and you'd need something with a powerful RF signal to mess up the head unit itself. The computer with its injector and spark outputs are probably the noisiest things but they really aren't powerful enough to cause issues unless you coil the RCA's or antennae wire around them. Last edited by Overdriven; 02-04-2017 at 05:32 PM. |
#16 |
meowMEOWmeowMEOW
In most car apps, the only thing that will potentially incur interference would be: RCA source cables, 3.5mm aux jacks, improperly shielded wiring (aka using construction wire in a car), or anything on the ethernet/cat5/6 network. Most swaps arent using CAT, and the LAN systems are insulated.
FWIW, I have my TAC module stuff mounted right behind the radio, and my ECM is in the passenger footwell area on the backside of the firewall.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#17 | |
I appreciate the advice. For what it's worth, I grew up in Adrian Missouri, not too far from where you are at. Thanks again! |
#18 |
I have my ECM and TCM mounted underneath my seat. Nothing fancy, just out of sight, out of mind.
#19 |
Old member
Here is a link for more spots. Mine is just sitting in the glove box.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=401254
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#20 |
#21 |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#22 |
#23 |
You didn't say it had to be OE
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#24 |
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
#25 |
