![]() Join Date: Jul 2013
Do i need new gauges now?
So i didnt think about it until after starting the truck, used to have inline 6 and now have a 350...the oil pressure stays buried on the H and after it warms up the temp is butied as well. Is that just bc these gauges were meant for the inline 6?
Re: Do i need new gauges now?
Are you using the same sending units on the motor? Sounds like you may have senders for idiot lights on the 350 where the 6 had senders made for gauges. i do not think there is a difference in the gauges from motor to motor other than the different pressures for the oil pressure which is either a 60lb or 80lb.
blue 68 c-10 work in progress yellow/white 72 Cheyene Sold! Green 71 Vw Bug ![]() |
#3 | |
![]() Join Date: Mar 2003
The gauges are just measuring tools, they don't care if the water or oil in inside of a 6cyl or V8. Get the correct senders with 90 resistance
Again my oil pressure is a copper line from the block to the guage, the motor had an electric sensor but i took it off and went with the copper bc it was cheaper to do that than replace my gauge as well. And the temp gauge on the truck works and slowly climbs but its reading all the way on the H and i know im not overheating, new radiator, thermostat etc
LMC shows the same gauges for 67-72, no difference for 6 or 8 cylinder engines
#7 | ||
"I ain't nobody, dork."
The oil pump in the 350 is probably either not as worn out as the old inline pump was, or the 350 has a high volume or high pressure oil pump in it.
My 350 with a HV oil pump is pretty much pegged until it warms up a bit. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Cool thanks! I unfortunately dont know what has or hasnt been done to this motor...i traded a little bit of my upholstery labor for it. It came out of a 78 camaro but the guy i got it from bought the camaro from an auction
I went from a 6 to an 8 and my old gauges are still working. The oil pegging H when cold is normal. The gauge only goes to 60 and SBC's hit 60 when cold. Mine comes down at idle when warm, and up close to H when driving.
My temp gauge works, but does not go past about 1/3, so I agree you need another sender. I used the one that was in my 6, and just screwed it into the 8. |
