02-03-2017, 06:18 PM | #1 |
Front Driveshaft
My front driveshaft is worn out where the slip yoke is, splines are shot. Will these interchange? It'd be nice to get rid of that double joint.
02-03-2017, 06:42 PM | #2 |
Re: Front Driveshaft
No, that double joint is in there for a reason. Get it rebuilt.
02-03-2017, 08:00 PM | #3 |
If you want more information, or you just have trouble sleeping, do a web search for CV-joint vs U-joint. (Constant Velocity joint and Universal Joint)
But the short answer is that driveline/pinion angles are different for those two different types of joints. It's actually likely it will FIT, but will result in vibration. That vibration isn't just annoying, it will also shorten the life of everything it's attached to.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
02-03-2017, 09:07 PM | #4 |
I didn't figure it would, I got a guy with several used ones, may go that route for now.
02-08-2017, 10:04 AM | #5 |
i had eliminated my double cardone joint when i did my 4l80 swap. and the vibration is only noticeable/ happens when in 4wd driving like 50+, so if that doesnt apply to you, or can live with it when you do drive in 4wd on the road then go for it.
i had used the front drive shaft from a 1996 suburban 1500 and i had to get a conversion ujoint to be able to mount it to the front yoke
1987 v20 regular cab - work in progress swapped in a (1992 tbi 350 with vortec heads) old motor. currently has an 8.1l and 4l80 swap. flatbed bed 2 inch lift and 64 inch spring swap in the rear. 2002 chevy 2500hd extended long- blackbear tune. DD |
02-08-2017, 08:17 PM | #6 |
You got the pt # on the conversion joint?
02-08-2017, 08:54 PM | #7 |
it was a s44 to a 1310
oreillys part # is MPJ 372
