Old 02-03-2017, 08:27 PM   #1
tim71
tim71's Avatar
Ground Straps
Hello, first post in this forum. I'm restoring a 71K1500 and I need a little help. When I disassembled the truck to begin resto I failed to take notes or get a picture of where the ground straps attach. I'm sure the engine grounds to the frame and the cab, and the cab grounds to the frame. I have a new ground strap kit has 4 straps in it (2long,2short), but I can't remember where they attach.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 02-03-2017, 09:16 PM   #2
bow-tie-bandit
Live life and be happy.
bow-tie-bandit's Avatar
Re: Ground Straps
Welcome to the board. This link should help a bit. Search is your friend
http://67-72chevytrucks.com/vboard/s...d.php?t=422234
bow-tie-bandit is offline   Reply With Quote
Old 02-03-2017, 09:25 PM   #3
B. W.
B. W.'s Avatar
Re: Ground Straps
Welcome to the forum, lots of great people here.
Can't help you much, this is what I got:
pic 1 - forward passenger frame rail to inner fender (fender removed)
pic 2 - under cab at front mount, passenger side
there's on on the bed also, don't have a pic
that's all I know
70 K20
B. W. is offline   Reply With Quote
Old 02-03-2017, 09:30 PM   #4
davepl
davepl's Avatar
Re: Ground Straps
Unless you're doing a perfect resto, what I did was to buy two kits and add extras. Ground problems are hard to track and since I was powdercoating everything I was extra-worried.
Unfortunately the kits you buy now aren't copper (maybe the Eckler's Corvette ones are, for example, but not LMC), they're stainless.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-04-2017, 09:53 AM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Ground Straps
See my blazer build here: http://67-72chevytrucks.com/vboard/s...9&postcount=53
Old 02-04-2017, 10:40 AM   #6
dfwright
dfwright's Avatar
Re: Ground Straps
Ground Strap Locations
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-04-2017, 02:42 PM   #7
tim71
tim71's Avatar
Re: Ground Straps
Thanks for all your help. Info even jogged my memory some.
