Old 02-03-2017, 11:27 PM   #1
1966chevyc20
Better highway drivability
I have a 1966 c20 with a sm420 and 4.56 rear end. It seems to be comfortable at around 50mph. I currently am swapping in a 350 for an engine. I would at least like to go 65 comfortably. So would the better option be a rear end swap or some type of overdrive tranny? If so what would be the easiest/most affordable to swap in?
1966chevyc20 is offline   Reply With Quote
Old 02-03-2017, 11:52 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Better highway drivability
Easiest and least expensive.
Get a 14 bolt out of a 73+ 3/4 ton with 3.73 gears. - So very common gears.
66 C20 Service Truck:
Old 02-04-2017, 02:21 AM   #3
nail pounder
nail pounder's Avatar
You may want to do the rear end as parts can be hard to find on the HO52(?) But I have a 350/NV3500 (5spd manual) in my C20 w/ stock rear end and at 65 mph the rpm is about 2100, at 80mph it spins about 2500. If you use yours like a truck it's actually a nice set up, 1st is still real low and 5th purrs on the freeway.
nail pounder is offline   Reply With Quote
Old 02-04-2017, 02:49 AM   #4
1966chevyc20
I have looked into an nv3500 swap. I just wasn't sure how well it would hold up to a mild 350 (around 350hp). Do you think it would hold up?
Old 02-04-2017, 09:37 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
NV3500's are only rated 330hp max, you would need to go with an NV4500 which is much beefier. Cost wise, the rear end mentioned above would be your most cost effective option.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-04-2017, 09:51 AM   #6
downeyballz
I swapped a nv3500 behind my 292 I-6. truck drives great, hydro clutch is nice and the trans is holding up fine. nv3500's are under-rated in my opinion.
if you plan on swapping the rear axle get one from a 1-ton square body (c30/k30) the leaf spring perches are in the correct location. later 1/2 & 3/4 ton trucks had wider spacing and outboard shocks.
I found this out the hard way
downeyballz is offline   Reply With Quote
Old 02-04-2017, 12:42 PM   #7
nail pounder
I think it all depends on what you plan do do with the truck. 3.73 rear end is a nice set up but you still only have a 1:1 ratio(sm420) in high gear. I've had no problems with my nv3500, BUT I don't hot rod it around, my tires are 31" tall BFG'S. It's not a burn out machine. In my 58 I have 350/700r4 with the stock 3.90 rear end and 28" cookie cutter tires, and it does great on the freeway and I can smoke the tires if I want to. Budget wise, price it out, both swaps take a little time to install. IMHO I think an overdrive transmission is a win win and then change the rear if you want.
Old 02-04-2017, 12:55 PM   #8
LostMy65
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...hlight=14-Bolt
Old 02-04-2017, 01:02 PM   #9
LostMy65
LostMy65's Avatar
My thread
http://67-72chevytrucks.com/vboard/s...80#post5689580
Old 02-09-2017, 03:07 PM   #10
rudyyloverboiii
So if I keep my 292 n I add an nv3500 I can keep my differential n have highway speeds?
If I keep the 292 n my sm 420 I would have to get a 73-87 3/4 ton (I have a c20) differential to get on the highway?
rudyyloverboiii is offline   Reply With Quote
Old 02-09-2017, 03:25 PM   #11
nail pounder
I have the stock rear end (HO52 4:56) in my 66 C20, 350/NV3500 5spd, and I run 80mph at 2500rpm. I thought about changing my rear end but I found that I didn't need to with the overdrive. Down the road if this one becomes a problem I will. If you change the rear you need to know what your getting as far as ratio. Not just any random out of a newer vehicle. Google "differential, rpm, mph, tire size calculator" and you will see what we are talking about.
