02-04-2017, 07:28 PM | #1 |
tail lights
Ok guys,,,What are you using for the brake, park and signal lights.Combo units? or separate lights. I installed a second light in the unit but not fond of the result. Looking for a factory all in one unit to look good on the 52
An object in motion will stay in motion till you run out of gas |
02-04-2017, 10:41 PM | #2 |
Re: tail lights
You can make it work with the original lights with a couple of diodes in the brake light feeds so they don't feed back when you hit the turn signal.
02-04-2017, 10:58 PM | #3 |
Re: tail lights
I would highly recommend led taillights. The stock ones aren't very bright and seemed like a possible safety issue to me.
http://www.classicparts.com/1941-53-.../#.WJaULes76rU |
02-04-2017, 11:58 PM | #4 |
Re: tail lights
I had very bad luck with a few different LED lights I bought for my Rambler. Here is a little thread on what I ended up doing, and I am very happy with the good old 1157 bulbs after adding reflectors to them.
Go to the #3 post and look at photo #11 and 12. http://www.hotrodders.com/forum/basi...ng-212015.html There are probably some great LED lights out there, but the ones I bought were crap, and the second pair wasn't cheap. I found that the most important thing is the reflector. I see broken lights at work every day, the LED lights from the manufacturers like Toyota and Mercedes and the like all have very good reflectors. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
02-05-2017, 03:58 PM | #5 |
Post Whore
Re: tail lights
I have a set of these to go on mine when I get that far..they are for a early 30s chevy car..the ones I got are repo and are LED with plastic lense and black housing.whereas originals are glass lense..ill, have to fab a bracket to hold them..
