Old 02-04-2017, 07:28 PM   #1
Bobby Pootz
Bobby Pootz's Avatar
Coil Recommendation for a 4/6 drop
I'm looking to get a 4/6 drop with my 1984 C10 and have seen many recommend the McGaughys kit but have seen bad reviews on their coil springs.
So I'm looking for a good coil spring for a 2" drop, any advice?
I've heard great things about the RideTech HQ Shocks and will probably place those on all four corners.
This will be a DD truck. Thanks in advance!
Rob
Bobby Pootz is offline   Reply With Quote
Old 02-04-2017, 07:54 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Coil Recommendation for a 4/6 drop
Belltech is a good choice.
Keith
Convert to disc brakes.
Old 02-04-2017, 08:45 PM   #3
bbbc10
Diggin The SquareLife
I had western chassis on mine belltech is also a good choice I wouldn't use any other brands for lowering besides them 2
bbbc10 is offline   Reply With Quote
Old 02-05-2017, 07:59 PM   #4
dec010974
dec010974's Avatar
Bbbc10, wow, that's says a lot. My thinking was just like Bobby points. I gotta rethink this one. I love the ridetech HQ's. I had a set on all 4 corners of my 1971 air ride c10.
dec010974 is offline   Reply With Quote
Old 02-05-2017, 08:02 PM   #5
dec010974
dec010974's Avatar
Here is my ride.
Old 02-07-2017, 09:32 AM   #6
Mark-L
Mark-L's Avatar
Following, I am also in the process of looking for a good 4/6 drop for my 86 I just bought
1973 C-10
250 Inline 6
Mark-L is offline   Reply With Quote
Old 02-07-2017, 07:56 PM   #7
bbbc10
As i n posted above belltech an western chassis have very nice parts also pick up some shock extenders for the rear also drop shocks on all 4 corners
Old 02-10-2017, 10:37 PM   #8
Bobby Pootz
Looks like a complete 4/6 drop kit from Belltech is going to be the solution, including the front and rear sway bars. Then add the Ridetech shocks on the corners. Thanks for all the replies and advice!
Rob
Old 03-13-2017, 09:27 AM   #9
Mark-L
Mark-L's Avatar
Are you just using springs or drop spindles?
1973 C-10
250 Inline 6
Old 03-13-2017, 10:50 AM   #10
Bobby Pootz
I'll have to use both as no one makes a drop spring that low. Plus the drop spindles maintains proper suspension geometry. Thanks!
Old 03-14-2017, 01:09 PM   #11
zach_carver
zach_carver's Avatar
We installed belltech in my brothers 87 and they seem to be very good. Also installed belltech shocks as well and a rear axle flip. Rides better then stock.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 03-15-2017, 11:38 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Rob
Belltech is the only one I know of that makes a drop spring thats not way too soft. I still prefer cutting a stock C10 coil. I have herad even better results come from using a stock C20 coil and cutting it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-15-2017, 06:53 PM   #13
SCOTI
SCOTI's Avatar
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-16-2017, 03:47 AM   #14
Nick_R_23
Nick_R_23's Avatar
Originally Posted by SCOTI View Post
x2.
x3. Cut a coil, makes these trucks perfect.
Old 04-13-2017, 05:10 PM   #15
Koz1
x4 you can get Moog springs 850-1500 lb range or so- you choose- then cut to desired ride height absolutely nothing wrong with trimming front springs
go on rock auto , look up c10,c20,c30 front springs- motor-home etc... it'll show rate
Koz1 is offline   Reply With Quote
Old 04-28-2017, 01:42 PM   #16
JohnJ@RideTech
JohnJ@RideTech's Avatar
We have a spring that equates out to about a 2in drop that we provide in our StreetGrip kits. They are made out of a premium, cold wound steel here in Indiana and provide a nice combination of ride quality and handling. I recently drove our 72 C10 with the StreetGrip kit on it to Dallas TX and back and the ride quality was better than that of my 2015 Camry (I know, I know..but I have an hour commute back and forth to work every day) I copied a link below for you to check out. All of the components in the kit can be purchased separately. Look over the pieces and give me some feedback if you guys don't mind.
http://www.ridetech.com/store/1973-1...ip-system.html
Feel free to shoot me a DM, Email or call me directly if any of you have any questions!
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 05-07-2017, 03:25 PM   #17
Bobby Pootz
Thanks for replying John! So if I get this correct, the 2.5" drop spindle and Street Grip Spring at 2" of drop will provide an overall 4.5" drop up front?
I also see that there are two choices in shocks for the front, the HQ and the Street Grip. Which would you recommend for a daily driver?
What shock would you recommend for a 6" rear drop with a C-Notch?
Just checked the website and it's nice to see RideTech also is now doing the front steering components, I'm going to get a set.
Thanks for the help!
Rob
Old 05-08-2017, 09:38 AM   #18
JohnJ@RideTech
Rob,
You are correct. It equates to about a 4.5in drop in the front.
The HQ single adjustable, smooth body shock comes in the StreetGrip kit. The shock in this kit was spec'd out for the mounting height this kit provides. We do have multiple stroke lengths available in the HQ line up.
If you can get me a measurement from the center of your top mount to the center of your bottom mount, I can figure out exactly what shock length you need.
Give me a shout whenever you get some measurements and we can get you squared away.
John J.
Sales/Tech
