Old 02-04-2017, 08:02 PM   #1
vintovka
vintovka's Avatar
Hood Emblem Pronlems
Should read HOOD EMBLEM PROBLEMS (dyslexic and can't spell either.)
Trying to attach the reproduction side hood emblems but its no go. These are the "3100" emblem for the 54 Chevy truck and are expensive. The slide on retainers seem too big to grab the emblem studs. The studs themselves seem too short to leave enough stick thru the hood to grab onto. Are there alternate ways to hold the emblems on? Starting to think everything I paid for from a big online vendor is crappola.
vintovka is online now   Reply With Quote
Old 02-04-2017, 08:16 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Hood Emblem Pronlems
What truck do you have? Advanced Design or Task Force? Which year?
For example, there is a difference between '55 and '56 Chevy side emblems beyond where they mount. (Below vs. above belt line) '56's don't fit '55 nor vice versa. On TF trucks they're not "slide on retainers' they're a sheeet metal nut that threads onto the stud coming out of the backside of the emblem.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-04-2017, 08:18 PM   #3
donandal
I don't know which ones you have, but the ones I have had studs on the back
that measured about .190 inch diameter. I didn't like those retainers either.
I carefully started a 10-32 die over the studs and threaded them about
two thirds of the way down.
I am using 10-32 thin nyloc stainless nuts on them.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 02-04-2017, 08:25 PM   #4
vintovka
vintovka's Avatar
Sorry its a 1954 chevrolet 3100 and can be seen in the attached build/progress link. Will investigate the 10/32 threading idea, Still a ripoff for what these cost, Vendors either don't check their stuff or don't care, Have had issues with almost everything from door handles to seat covers. Sure I'm not alone in this.
Old 02-04-2017, 08:31 PM   #5
donandal
I agree to a point... the parts often don't fit exactly,
but compared to my badly pitted originals these are nice.
I have come to expect a little problem or two.
If you try to thread them, use plenty of cutting/threading fluid.
I use Tap Free II. I'm sure those studs are cast and somewhat
fragile so go SLOW!
53 Chevy Pickup
Old 02-04-2017, 09:01 PM   #6
vintovka
vintovka's Avatar
[QUOTE=donandal;7848551]I agree to a point... the parts often don't fit exactly,
I agree on the go slow part and will give it a try, As for the parts i have seen some by same vendor on a 57 chevy bel-air and the parts are pretty bad. They do lower the value of what was a near perfect restoration. This is my first attempt at a restoration and its a shock to see vendors continue to offer such crappola just because they can.
Old 02-04-2017, 09:55 PM   #7
Hampshire
Hampshire's Avatar
...how very right you are & you have lots of company.
Hampshire is offline   Reply With Quote
Old 02-04-2017, 10:37 PM   #8
mr48chev
mr48chev's Avatar
If you search the little slide out bins above the bolt bins at Ace hardware you might find some slip on clips or pal nuts that will fit tighter. The Pal Nuts are the stamped sheetmetal nuts Dan mentioned earlier.
My ongoing truck projects:
