Dash Bezel Differences....Will It Fit?
Does anyone know if a '75-77 bezel will fit a 1985?
The difference in price for new is quite substantial. As long as the screws line up and the gauges line up everything else could be reworked. Does anyone know or have they tried to make this work? |
Diggin The SquareLife
Re: Dash Bezel Differences....Will It Fit?
it will fit but u will the dash for 73-80
![]() Join Date: Oct 2014
If you have the correct dash in the 85 truck, then no.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
I spent several hours at a local Pick-N-Pull one day testing the dashboard swaps.
Now, I have to admit I never looked at the particular combination you're asking, a 75 bezel and an 85 dash, but I DID look at the opposite combo, a 85 bezel and a 75 dash. If I recall correctly, this combo did indeed mount fine, but it left a very unsightly gap around the bezel, just plain ugly. However, in the many discussions that followed, a few people did say the combo you're asking about, the 75 bezel and 85 dash, looked acceptable.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
#5 | |
As wilkin250r said, an 81+ bezel leaves a rather unsightly gap when placed up against a 73-80 dash pad. But when going the other way around, the 81+ dash pad overhangs the top of the bezel enough that it shouldn't look too bad.
Another issue to deal with is going to be the headlight switch location. When GM moved the wiper switch onto the steering column, they also moved the headlight switch up just a little higher on the dash. That will prevent it from lining up with the hole in an earlier year bezel. You could probably fix that issue by drilling a new hole in the metal dash structure and moving the headlight switch back down to the earlier location. And of course you'll be left with an unused wiper switch opening in the older bezel. |
#7 | |
thx everyone |
you need the dash and bezel, have done this swap, put a 70's dash and bezel in a 81 suburban
#9 | |
Either way, the guy brought me the bezel for the truck so I have one... ![]() Saturday is supposed to 37 and I have the day off so I may spend some time in my garage. |
