02-05-2017, 03:49 AM | #1 |
VA72C10
1972 Big Block Setup complete or sold individually
I'm going to be using the big block itself and th400 in my new swb build. Everything else will be for sale including the carb and potentially the intake. I have the rest of the truck being parted out on the suburban page. http://67-72chevytrucks.com/vboard/s...d.php?t=729486
All prices picked up or plus actual shipping. Would like to sell all together first and will give it a few days. Update 2/8 Sorry for the delay. Have been taking my evenings to help my parents out with home inspection items after my dad hurt his shoulder. Will have some time tonight to start taking things off the truck and getting the pictures requested. Package deal for everything related to the Big block minus long block and smog parts including headers 1500 picked up or 1550 plus actual shipping A/C brackets (without smog bracket) with all bolts/washers/nuts 320 PS Pump with all brackets and bolts/washers/nuts 250 Alternator brackets with all bolts/washers/nuts 160 BB pulleys 175 72 BB motor mounts with clamshells and bolts 180 Air cleaner with spark arrestor 150 7042218 carb 150 th400 kickdown bracket with wiring Exhaust hangers 4 core rad mounts upper and lower with rubber 80 BB fan shroud 100 Original radiator Heat riser (tube good- bottom shield is rusted) Wire loom pieces Spark plug heat shields Heat shield for cab 40 BB wiring harness still flexible and complete 100 These parts are also for sale locally and local pickup preferred to shipping.
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 02-08-2017 at 01:52 PM. |
02-05-2017, 07:03 AM | #2 | |
Posted via Mobile Device |
02-05-2017, 09:34 AM | #3 |
VA72C10
Re: 1972 Big Block Setup complete or sold individually
Okay, let me see if someone wants all the big block brackets first. I also replied to someone's wtb thread asking about the smog setup so I'm going to consider them first in line if I separate. You will be next in line if they pass.
Looking for a 67-72 swb or blazer project in or around VA. |
02-05-2017, 09:39 AM | #4 |
Interested in the condition (pictures if possible) and price of the exhaust hangers.
Thx
Tony 1972 Chevy K10 SWB Custom Deluxe 350|350|NP205 2018 GMC Sierra Z/71 Crew 2008 GMC Yukon 2007 Chevy 1500 LT 1967 Pontiac Firebird 400 |
02-05-2017, 10:10 AM | #5 |
I'll take the cab heat shield and the TH 400 kick down cable
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
02-05-2017, 10:27 AM | #6 |
Inline for exhaust hangars
02-05-2017, 10:56 AM | #7 |
Junior Member
interested in the turbo 400 kickdown bracket with wiring and switch if tdrcreyn4 doesn't take it.
02-05-2017, 10:58 AM | #8 |
How is the carb, does it need a rebuild?
02-05-2017, 11:09 AM | #9 |
Pm sent ..
02-05-2017, 11:29 AM | #10 | ||
VA72C10
Okay, I will get them removed and pictured and give you first option. noted. Quote:
It has been sitting for some time so I'd assume a rebuild would be needed. Looks good overall and truck has 48k miles. I will put you first in line for engine/frame brackets and hardware. Please remember to post in thread vs pm for future as no pm sales are allowed. Price is 180 shipped.
02-05-2017, 11:32 AM | #11 |
Carpe manana
Cost shipped on the radiator? Any idea if usable as is or could be rebuilt?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-05-2017, 11:36 AM | #12 |
VA72C10
It looks very good but when I went to fill it I got a leak. Going to remove to see where leak is. It's possible the drain cock is open. Haven't had a chance to look. Will remove and fill and note any leaks and send pictures and Price according to condition.
02-05-2017, 11:38 AM | #13 |
Carpe manana
Check. Thank you. I'll stay tuned.
02-05-2017, 11:39 AM | #14 |
Will you sell the steering column and shifter linkage?
02-05-2017, 11:53 AM | #15 |
Price shipped on the heat riser tube o 98409. So your selling the A/C brackets and the SMOG pump assembly together? Willing to sell the smog setup separately? I think the water pump pulley is specific to the smog pump.
02-05-2017, 12:09 PM | #16 |
I am interested in smog setup complete
02-05-2017, 04:28 PM | #17 |
I posted asking about the column...sent you a pm about the column...you said you have people interested in it on your facebook ...I do not do facebook...but if you don't mind would you let me know if it is available to me or not so I can be looking elsewhere...I do want the bigblock mounts and parts
Thanks |
02-05-2017, 04:59 PM | #18 | ||
VA72C10
Heat riser tube 85 shipped. You have first dibs. Are you wanting everything including manifolds/air tubes and the brackets? Do you have the other Big block brackets that bolt to the smog bracket? Quote:
02-05-2017, 05:34 PM | #19 |
The system was pulled from my truck and exhaust manifolds were plugged so would like everything
02-05-2017, 05:57 PM | #20 |
02-05-2017, 06:39 PM | #21 |
Ok, since separation of the A/C and smog is up in the air....I will take the A/C and Smog set up complete as listed for $320 plus shipping.
02-05-2017, 07:54 PM | #22 | |
VA72C10
67 kid will have first dibs on smog setup once I decide what to do.
02-05-2017, 08:26 PM | #23 | |
02-05-2017, 08:28 PM | #24 | |
02-05-2017, 08:41 PM | #25 |
Interested in fan and shroud, interns in power steering set up with reservoir depending on price.
