Instrument Cluster
Looking to put a new instrument cluster in my sons k10. Any advice or suggestions? Looked at LMC, Intellitronix, DakotaDigital. Present one very rough.
1972 K10 w/350 & 6" lift ![]() |
Re: Instrument Cluster
I bought mine from brothers so I could do my own gauge selections. I like it.
if all the gauges work they're not hard to restore yourself just changing the glass and outside cover make a huge difference and not a lot of money compared to the digital alternatives
Old member
I just pulled the cluster out of my Ramp truck and cleaned it good and painted the needles and reset the mileage to 00000!
Made a world of difference. Before and after. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I can't say enough good things about Dakota Digital. Very easy to wire, pretty much plug and play for my application. Tons of features, it's expandable, and the instructions are well written. Pricey, but worth it.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
![]() Join Date: Sep 2015
I redid my stock gauge cluster to look stock with four new lower guages.
I added a modified late model bmw dash clock, I installed a battery movement from a hobby shop, and made up the glass cover for it from a sheet of plastic from the hobby shop also. I left the stock dash lower glass in place that shows, battery, temp and oil. I used autometer autogage 2-1/16" gauges. You can see the voltage guage in the place of the stock amp gauge. The autogages your going to have to remove their stock glass fronts, and repaint the needles orange and paint black over top of the autometer words on the guage. I added a vacume gauge in the spot next to the oil gauge. |
JMD -
Thanks for the pic. Looks great and glad to hear about the instructions!
Intellitronics is a crap shoot, you might get a good 1... if not you have wasted a bunch of time. And are no closer to nice gauges that work.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
#9 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#10 | |
Old member
![]() Quote:
Unless it is a very custom truck I prefer the stock gauges, that's just my opinion
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Old member
I took a nice cluster out of the ramp truck and installed a cluster with Tach. I'm keeping the old school look on the Ramp Rat.
![]() The one I took out. The new one with tach:
#13 |
Thanks for that. Not wanting to have to do this again!
#14 |
Thanks. I do not disagree. Saw you use the GPS speedometer on your 71. How do you like that?
#15 | |
Old member
![]() Quote:
I love the GPS in my 71. ![]()
#16 |
Andy4639 - Did it fit with the stock bezel in your truck?
#17 |
I haven't installed mine yet as Im still finishing the wiring, but the New Vintage USA gauges from LMC are gorgeous! They did an awesome job replicating the factory look!
#18 |
Old member
It's smaller I had to cut the inner panel to make it work.
#19 |
Looks great! Nicely done.
