![]() Join Date: Mar 2012
Porterbuilt stuff
I am currently redoing my frame to include wire-wheeling and sanding the frame so i can OSPHO it all before i paint it,
I was looking at some replacement items from Porterbuilt Like the items below, My question is are these Items direct replacements or are they only for lowered trucks I want to keep the truck the stock height and stance http://pbfab.com/63-72-trailing-arms...ece-driveshaft http://pbfab.com/rear-frame-crossmember-63-72 http://pbfab.com/panhard-bar-crossmember http://pbfab.com/67-72-front-tubular...rt-crossmember http://pbfab.com/transmission-crossmember I would like to use all the stuff above just want to make sure i can use regular springs and new trailling arms for a stock height
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Oct 2012
Re: Porterbuilt stuff
most of there stuff is for lowering your truck.....A1 quality too.
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
So what can I use and keep the truck a factory stance, I am just wanting to beef up the frame when I place the rear springs and trailing arms
Check out Early Classics Enterprises. ECE
