Neutral Safety switch backup light connector
Hello,
Attached is a picture of my neutral safety switch back up lights terminal. Can you tell me if the dark green and the light green wires are correct on the terminal. I've seen other pictures that the dark green wire should be on the top of the wire connector. since that is the power wire. thanks, Ramiro |
Re: Neutral Safety switch backup light connector
It won't make any difference.
laying low
![]() Join Date: Mar 2001
Right. You are merely completing a circuit so wire placement makes no difference on the switch.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Thanks Wrenchbender Ret and Boog.
