Old 02-05-2017, 04:33 PM   #1
rocket_customz
rocket_customz's Avatar
Long tube headers for 5.3L swap
What long tube headers are you guys using for ls swaps? Truck or car applications?
1966 Chevrolet
5.3L LM7, cammed, ported and polished
4l60E, manual valve body
Throbros front dropmember,Custom 2 link rear with watts link
Ridetech control arms, Accuair air management
rocket_customz is offline   Reply With Quote
Old 02-05-2017, 04:43 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Long tube headers for 5.3L swap
Doug Thorley is the go to. They have 1-3/4" and 1-5/8"
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-05-2017, 06:49 PM   #3
rocket_customz
Do the 99+ truck headers fit or do I need to get a set for a camaro or gto?
1966 Chevrolet
Old 02-05-2017, 07:28 PM   #4
jweb
jweb's Avatar
I plan on using the Speed Engineering headers.
Here's some more info on them
http://67-72chevytrucks.com/vboard/s...d.php?t=711185
jweb is offline   Reply With Quote
Old 02-05-2017, 07:35 PM   #5
rocket_customz
Thanks for the info. Those look like the way to go
1966 Chevrolet
Old 02-05-2017, 08:51 PM   #6
PGSigns
PGSigns's Avatar
Look in the LSX swap section there are lots of info in there.
http://67-72chevytrucks.com/vboard/f...play.php?f=206
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-05-2017, 09:44 PM   #7
Clyde65
Clyde65's Avatar
Stock truck header will need frame surgery, the TBSS manifolds work very well, they are shortied tho. Hooker makes an aftermarket version of the TBSS.
Shorties are fine for stock or "tuned" applications, if cam swap and added power, you need long tube.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-05-2017, 10:40 PM   #8
racecougar
racecougar's Avatar
We went with Speed Engineering 1-7/8" headers.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 02-05-2017, 11:09 PM   #9
jweb
jweb's Avatar
The Speed Engineering website does say they require slider engine mounts to clear the front crossmember. Not sure if that's what you are using or how true it is.
Old 02-06-2017, 08:58 PM   #10
racecougar
racecougar's Avatar
We used the stock '65 230ci perches, stock replacement mounts, and Speed Engineering's motor mount plates...no clearance issues.
Old 02-07-2017, 12:02 AM   #11
jweb
jweb's Avatar
That's good to know, those are way cheaper than the Dirty Dingo sliders.
