Old 02-06-2017, 12:51 AM   #1
custom10nut
custom10nut's Avatar
Suggestions for cleaning rear slider glass channel?
The glass channels on my rear slider need to be cleaned.
They're in good shape but are just dirty.
I haven't installed the window yet so I can move it around however I need to.
Will a good soaking with a household cleaner work to loosen the ground in dirt?
Followed by spraying it out with a pressure washer?
Will I tear up the channel if I do it this way?
custom10nut is offline   Reply With Quote
Old 02-06-2017, 07:37 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Suggestions for cleaning rear slider glass channel?
Get a old tooth brush and soak the area good with soap and warm water then scrub away!
You coming up to Mrytle beach for the show in March?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-06-2017, 09:30 AM   #3
cherokeejohn
cherokeejohn's Avatar
x 2 on what Andy posted. Warm soapy water and a nylon brush/tooth brush should do the trick. if its really caked up in it, as mine was, it even had moss growing in it, before you get to the brushing stage, a old Popsicle stick works good to dig out the old crud, again use soapy water with it too.
72 C/10, LWB, 5.7, Auto, with A/C
F.B.I = Full Blood Indian
Appalachia/Eastern Cherokee,"Tsalagi"
cherokeejohn is offline   Reply With Quote
Old 02-06-2017, 09:57 AM   #4
custom10nut
Thanks to both. That's my project for today. Andy, PM me with the dates and details of the MB show. I'd like to go if I can
Old 02-06-2017, 11:16 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I have use air but you have to use really low pressure or you will blow the felt out, especially if it is a little rotten. I tried the toothbrush as the others suggested and it worked OK. I had to grind it down some because it wouldn't fit in the channel.
LockDoc
Leon
