02-06-2017, 01:54 PM | #1 |
Opinion poll on custom exhaust setup
Hey guys,
I'm getting exhaust done on my 72 stepside truck later this week and have a couple questions looking for opinions. As background info, Im building my truck to a near show quality (not quite barrett but maybe mecum lol). The questions: 1) Position: Im playing with the idea of having the pipes exit to the sides of the truck, either under the steps (with dual or even quad tips on each side (hot wheels-esque) or dual on each side behind the rear tires or just two or quad pipes straight out the back or lastly dump somewhere underneath and call it a day 2) Finish: Plain ol' aluminized pipe or send em out for silver ceramic coating to match my long tube headers (thinking about that undercarriage glamor shot on barrett jackson the day I decide to sell it... A guy can dream right?) Pics/opinions welcome! Last edited by jsera; 02-06-2017 at 02:00 PM. |
02-06-2017, 01:57 PM | #2 |
Re: Opinion poll on custom exhaust setup
Pics:
02-06-2017, 02:13 PM | #3 |
I would exit behind the rear wheels and by all means do the coatings if your budget allows
70 SWB STEPSIDE 70 BLAZER 09 challenger |
02-06-2017, 02:16 PM | #4 |
I prefer behind the wheels. It looks more finished to me, and it also gives a little better sound insulation for the cab.
02-06-2017, 02:22 PM | #5 |
Mount your exhaust dump/cutout behind the cab just under the bed having that route to your 4 pipes exiting directly under each step. Route the normal, muffled pipes straight out the back.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 02-06-2017 at 02:29 PM. |
02-06-2017, 10:39 PM | #6 |
I'd vote for mandrel bent stainless for the full exhuast.
Otherwise aluminized pipe and some paint looks great. I wouldnt get it ceramic coated unless you wear doing it for heat manangement. |
02-06-2017, 10:47 PM | #7 |
Go all the way out behind the rear wheels. In front of the rear wheels and you won't enjoy driving it. Too much drone in the cab.
02-06-2017, 10:56 PM | #8 |
I would go straight out the back, single tipped pipes. Sounds better than one out each side.
02-07-2017, 07:17 AM | #9 |
Old member
I have a LWB fleet bed truck and ran mine all the way out back turned to each corner of the truck and angled down.
02-07-2017, 07:46 AM | #10 |
No matter what you do, single outlets, That multi-tip stuff is for imports
02-07-2017, 07:57 AM | #11 |
x2
02-07-2017, 08:51 AM | #12 |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-07-2017, 09:03 AM | #13 |
Andy, how are your clearances from exhaust to bed (in my case would be wood) and to the axle and panhard bar? I was looking under my truck last night and realized that with the 4" drop the clearances for taking the exhaust all the way back kinda sucks...
02-07-2017, 09:09 AM | #14 |
How about something like this on each side? I don't think it looks ricey?
02-07-2017, 09:29 AM | #15 | |
Old member
Mine is close for sure but nothing hit's. Compared to my Impala, You should see the 64 SS Impala if you want close. The double tips are fine just don't put one of those bee mufflers on it!
02-07-2017, 10:16 AM | #16 |
02-07-2017, 10:29 AM | #17 |
Old member
Yes nothing hit's even when the rear air bags are all the way down.
02-07-2017, 11:31 AM | #18 |
My .02 is as follows.
I don't like the muffler shop pinch bends. I'd use mandrel bent pieces welded together. A bit of a pain but it just looks so much better. Doesn't have to be stainless. You can buy kits with bends and straight sections. Also depending on the progress of you build I wouldn't run it under the cross member I would punch holes in the cross member and run the pipes thru the cross member so you can't see the exhaust pipes from the side. I would run the exhaust all the way to the back but out the side before the bumper. At the end of the pipe instead of leaving it cut 90 degrees I like to cut them at an angle so the end is more or less square to the ground leaving maybe and inch or so below the rear bed side. Again just .02. |
02-07-2017, 11:52 AM | #19 | |
02-07-2017, 12:19 PM | #20 |
I talked my dad into putting the stainless flowmaster kit on his 70. He was hesitant but now I think it's one of his favorite parts - the sound! Fits great and they give you exit options. If I remember right we modified 1 of the options - they exit straight out the back with a very very slight down bend (cleanest look in my opinion)
http://www.flowmastermufflers.com/19...st-kit-817654/ |
02-07-2017, 01:00 PM | #21 | |
02-07-2017, 01:21 PM | #22 |
I cut the hole in the cross member with a plasma cutter with the cross member in place in the frame and then welded in two round rings to reinforce the area around the holes. I did 4" holes so I would have 1/2 clearance around the 3" exhaust pipe.
02-07-2017, 02:03 PM | #23 |
If your going that far you can allways add those electric cut outs and dumps somewhere. And still go out the back.
Diggin the hot wheels kinda thing too just to be lil' differnt but it's not for everyone. I think the one Stacey David did with the wobbly up sweeps were cool.but its not for me. I prefer them anywhere out the back. I chose this way cause it was either cutouts on the bumper or having exhaust tips a few inches off the ground under the bumper. I had the camaro's exhaust exiting in this same location except for more pointing to the ground and I didn't like all the dirt and dust it kicked up. It looks here like my bumper will catch the fumes but it really just "looks" that way. I shoulda stuck with my original plan and narrowed one of the many spare bumpers i have and made the exhaust cutouts in it like I wanted too. But I like it this way too.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
02-07-2017, 09:46 PM | #24 |
Where's my beer?
On my stepside, my pipes come out under the steps at a 45 degree angle and I love it that way. Wouldn't want it any other way. On a truck as nice looking as yours I think ceramic coating the entire exhaust system would be a very nice touch.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
02-17-2017, 09:33 AM | #25 |
Just got my truck back from the muffler shop last night and it looks awesome! I went with the Quad tips under each step and Im glad I didn't stick with the norm it looks great and really unique. Props to the shop that did it, Muffler City in Jacksonville incase anyone around Jax needs some help in the future.
Note: the angle of the close ups makes it look like they stick out a lot but theyre just barely protruding as seen in the first pic. |
