Old 02-06-2017, 09:07 PM   #1
diveplane
cruise control issue?
cruise control is not enabling anymore
anyone have any ideas , will check the fuse
diveplane is offline   Reply With Quote
Old 02-06-2017, 10:28 PM   #2
diveplane
Re: cruise control issue?
what fuse is it guys is it 20amp?
Old 02-08-2017, 07:09 PM   #3
diveplane
bump on this anyone?
Old 02-11-2017, 01:03 AM   #4
UKNOWME
UKNOWME's Avatar
First, what are you driving?
Second, what size fuse was already there?
Third, my first guess is brake switch. Disclaimer strictly a guess.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 02-11-2017, 01:09 PM   #5
diveplane
this easy enough to do?
and part number?
chevy 1500 w/t 94 v6
manual 5 speed.
Old 02-11-2017, 03:09 PM   #6
UKNOWME
UKNOWME's Avatar
AC delco part# D1565E
It's located at the brake pedal. Should be pretty simple.
1964 Chevy c10
Old 02-11-2017, 06:07 PM   #7
diveplane
my brake lights are working why would cruise control not work then?
Old 02-13-2017, 11:54 PM   #8
diveplane
this a easy enough job just replace no adjustments?
got the new switch.
Old 02-14-2017, 09:33 AM   #9
ChevyTech
There is no adjustment to do on the brake light switch on the 1994 style switch, but many people struggle to get the clip off to remove the old switch.
I may not be near as easy as you think it will be.
Old 02-14-2017, 12:59 PM   #10
diveplane
yea i have manual gears so i have 3 pedals on floor trying not to remove any parts to gain access to it, if i have to i will.
Old 03-05-2017, 08:43 PM   #11
diveplane
ok installed the new brake light switch was quite a easy job really
, but still no cruise control?
is there a test to check module under hood?
anyone thx.
Old 03-06-2017, 12:34 PM   #12
diveplane
bump anyone thx..
Old 03-11-2017, 05:57 PM   #13
ironroad9c1
Master Hater
More than likely its the switch on the turn signal stalk. You really need to learn to troubleshoot instead of buying parts. get a semi-decent volt/ohm meter and google for diagrams and start reading wires. you need an account to view this but its worth the sign up.
http://www.73-87chevytrucks.com/tech...se_Control.pdf
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 03-11-2017, 11:17 PM   #14
Joep
My 88 4.3l v6 5 speed. My cruise doesn't set correctly. And yeah. It is in the stalk. It works if I turn it off then then on and set it, then push resume. It sets and holds and then I can increase speed by bumping the resume accel but I cannot decrease it using the set decel button. You can try this it is not a fix but did allow for me to get relief when driving.
Joep is offline   Reply With Quote
Old 03-11-2017, 11:29 PM   #15
Joep
There are two switched on the pedals for the cruise and one for the brake lights. The switches for the cruise can be tested with a multimeter. They will be no resistance when normal ie pedal up and have resistance when activated is pedal pushed. The brake light is opposite open pedal up and closed pedal down.
Old 03-12-2017, 09:16 AM   #16
Marv D
Registered Truck Offender
Marv D's Avatar
Don't forget on a manual trans there is also a release / trip switch on the clutch pedal to disengage the cruise if you depress the clutch. (like Joe is saying) My 94 the pedal linkage had 'sagged' just enough that if I hit a bump it would trip the switch. There is no adjustment on that one and I just wrapped a piece of tape around the pedal.
Easy test,, use your toe to lift the pedal. If the cruise will work until you let it hang free,, you found the culprit
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-12-2017, 07:30 PM   #17
Chevyaz
Thats some really good information on the cruise control. Thanks guys.
Chevyaz is offline   Reply With Quote
Old 03-16-2017, 11:45 AM   #18
diveplane
i tried the tip on clutch lifted it up no success, so i think its my switch thats worn out, or the cable has a break.
