Old 02-06-2017, 10:55 PM   #1
69GMCLonghorn
69GMCLonghorn's Avatar
Crank on, Crank on...
WELL! My 70 C10 is coming along. I got the ground wires hooked up tonight and decided to see if it would at least crank (first time in about 2 1/2 years!). At first, nothing. Then I cleaned a couple connections and hooked up the charger to the battery. It cranked slowly... but wouldn't STOP when I turned the key off! I pulled the negative terminal off, checked some of the basic connections (starter, etc.) and tempted fate and tried it again. Same thing happened. It started cranking and wouldn't stop.
I've heard of this before but usually it's something obvious. Anybody have any ideas??
69GMCLonghorn is offline   Reply With Quote
Old 02-07-2017, 08:01 AM   #2
scooterpimp
scooterpimp's Avatar
Re: Crank on, Crank on...
Stuck starter solenoid , sticking ignition switch? Incorrect wiring hookup?
scooterpimp is offline   Reply With Quote
