Old 02-07-2017, 12:13 PM   #1
Mattchu60
Cracked plastic trim - how to fix?
I have a donor parts truck I have been pulling parts from. One of the things I got out recently was the headliner trim and the corner post trim. Two of the corner post trim pieces are cracked, each has a crack about 2-3" long. Anyone have a good way to repair?
The thought I had was to super glue or hot glue a supporting piece of plastic on the backside. Anyone have a better idea?
Mattchu60 is offline   Reply With Quote
Old 02-07-2017, 12:39 PM   #2
TKCR
TKCR's Avatar
Re: Cracked plastic trim - how to fix?
I have seen a thread in the past about this subject. I want to say they used that JB weld stuff? I'm not positive on that though.
Try and do a search, I'll do the same, and see if we can find it.
Old 02-07-2017, 12:41 PM   #3
TKCR
TKCR's Avatar
Here it is:
http://67-72chevytrucks.com/vboard/s...broken+plastic
Old 02-07-2017, 01:04 PM   #4
Mattchu60
Thanks - looks like they used a soldering iron to weld it together. May try that.
Old 02-07-2017, 01:06 PM   #5
frenchy51
frenchy51's Avatar
I have the same problem with some of my wood grained plastic trim. I was thinking of JB weld then having it vinyl wrapped with wood grain....Anybody tried that?
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 02-07-2017, 02:36 PM   #6
tucsonjwt
I used Harbor Freight $1 per small tube epoxy and glued a thin piece of sheet metal to the back to prevent flexing. Then I used the same epoxy to fill the crack on the face of the trim. If you are painting over the trim it won't be noticeable.
tucsonjwt is offline   Reply With Quote
Old 02-07-2017, 04:53 PM   #7
Ziegelsteinfaust
I have heard either abs or pvc glue work good. I just can't remember which one it is
Ziegelsteinfaust is offline   Reply With Quote
Old 02-07-2017, 09:33 PM   #8
Mattchu60
Thanks for the ideas - I used a soldering iron to melt it back together today. Seems to have made a pretty strong joint.
