![]() Join Date: Oct 2010
1972 SWB Drive Shaft Length.
Hi all, I am sure this has been discussed many times. I have a 1972 SWB with a 400 sbc and turbo 350 (short tail shaft) I have a 2 pc drive shaft to go in it. But a friend knows of 1 piece driveshaft the owner sears came out of a 1972 6cyl 3 speed. Was wondering if anyone might know what the length should be on a drive shaft, center to center of the ujoints?
Thanks Eddie |
Re: 1972 SWB Drive Shaft Length.
in this case cit is far better for you to get under the truck and measure what you need to get the right measurement
![]() Join Date: Jun 2005
Which frame holes are your engine stands bolted to, front or rear?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
1968 c10 swb
SBC 350 on the front mounts Turbo 350 short tail 59.25 driveshaft |
I had to have my drive shaft lengthened by 4 inches when I did my 6 cylinder to 350 swap, but I kept my 3 speed manual transmission. This is using the forward mounting holes for the v8.
You really should measure. Mine is 350 on front mounts/700r4/ 55 9/16 shaft. All I had was the trans yoke and it cost me 230 out the door for new one.
