![]() Join Date: Nov 2008
72 jimmy Help IDing rear diff disc brake rearend
Ok so I just got this jimmy and it has no ebrake setup so I'm trying to figure out where the rear diff was out of to get hardware here are the numbers any help would be appreciated
Re: 72 jimmy Help IDing rear diff disc brake rearend
can you post a photo of the diff cover and the complete rear end?
1968 Chevy C-10 Suburban - 350/350 1969 Chevy C-10 Panel Delivery - 454/400 1972 GMC K1500 Jimmy - 350/350/np205 1978 Chevy Corvette Silver 25th Anniversary reddit.com/r/chevyc10 <-Join it! |
![]() Join Date: May 2011
I have an ebrake set from pedal to connector that attach to the cables coming out of the rear. Let me know if interested and I can get some pictures.
The truck is still in nh and I'm on cape cod but I'm picking it up on Sunday when I get back il take some pics
So where can I find an ebrake setup for that disc brake rearend?
There are many different options/solutions for 14 bolt rear disk conversions. Just keyword search "14 bolt disc" for starters. Much has been written on this board and elsewhere on the topic. For bolt-in axle rearends, I wouldnt hesitate using a pinion caliper system, otherwise the modern pickup truck "drum-in-hat" systems are better than the old Cadillac caliper systems.
..the factory 14 bolt drums are not bad, but if you wish to keep rear disks and full floating axles, it may be cheaper to just swap the whole rear out to a more modern 10.5" rear with factory integrated rear discs & drum-in-hat parking brake. Heres a list from the pirate4x4 board that someone offered those applications;
Nbs 1999 -to- (pre June) 2010 chevy 2500hd-3500hd 6.0 ltr gas trucks are standard 10.5 Aam ff 14 bolt. Post June have larger lug pattern Chevy 2500 avalanches and 2500-3500 vans with 6.0s optional and 8.1s standard as well. 2500 suburbans had a optional 14 bolt ff in 99-2010 as well with the 6.0 and 8.1 Chevy 2500 non hd have 9.5 sf with disc brakes as well as the 1500hd and standard 2500 suburban 99-2010 Chevy 2500hd-3500hd with 8.1 and duramax have 11.5 disc brake rears unless ordered otherwise |
Sorry, I didn't get it pulled off this weekend. Went to the junkyard Saturday and it rained Sunday. I think this coming weekend is going to be decent, 100 for everything and it should fit in a medium flat rate for 15 shipped please let me know if still interested before I pull it.
Actually I'm going to have to wait I'm out of money until my van is sold
Here's a shot of the rear diff
#13 |
Here's a shot of the rear caliper
#14 |
Distance shot of the rear caliper
#15 |
14 bolt with C20 front calipers on the back. Pretty common swap from what I hear.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#16 |
So does anybody know what calipers I can get that will bolt up that have ebrake hardware
#17 |
Collector of Projects
