Help me diagnose failures on first test drive
Hey guys, had my first test drive last night and didn't make it out of the neighborhood. Took a couple laps around the block and then decided to head for the open road and that's when the fit hit the shan...
steering was kinda squirrelly but I ignored it and kept going. As I was making my way towards the road, I hear a pop or a ping (some sort of onomatopoeia) and immediately stopped and put the truck in reverse thinking something might have fallen off. As I was going in reverse, the engine stalled and I found myself stuck in the middle of the street. The truck wouldn't start (though it would turn over) and so I pushed it over to the side of the road to await a tow back to the house because Id never get up the driveway pushing on my own. To get the truck to the side of the road I had to turn the wheels and that's when I noticed a dead 2-4 inches of steering with a clnk somewhere in it as you turned the wheel back and forth. The tow driver helped me narrow it down and as I turned the wheel, he says the clunk seemed to be coming from inside the steering box (power steering box-which is brand new) I had also checked for any loose linkages and found none. So my questions: 1-What might have caused the pop and engine to stall and not turn back on? I suspect it may have been low on fuel but I thought it would have enough to get to the gas station-Ill try this later. I also had removed the cap and checked that the rotor did spin when cranking so its not a timing chain. 2- Whats the clunk in the steering box and what do I do to fix it? |
Re: Help me diagnose failures on first test drive
Anyone? I'm supposed to take it in to the muffler shop today and am hoping to fix it in time
![]() Join Date: Jan 2001
A description of the truck might help. What engine, transmission, carb, and distributor, for example?
Also, where did the brand-new steering box come from? |
Cause of you stall is likely to become obvious once you start troubleshooting the no start condition.
With respect to the steering, put the front up on jack stands. Observe the steering components while somebody else is turning the wheel. Use a stethoscope ( any solid rod: broom handle, screw driver, wire hanger, etc ) to narrow down where the noise emits from if naked ears can't get it. If it works fine like that, do the same again but with the suspension loaded. Any pictures? Interested particularly in you shifter location on the floor ( just curious with T56 ). -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#6 | |
Cardone units are hit-and miss. They're not new, they're supposed to be remanufactured. It's possible the problem is in the remanufactured unit. You mentioned that it was squirrelly when you started driving, which is often a gearbox problem in Chevy trucks. But it would also be important to check the rag joint, tie rod ends, etc.
Try feeding a little bit of gas through the carburetor. If it fires, it's likely you have fuel starvation. It could be out of fuel (you mentioned it was low) or it might be a carb, pump, filter, or fuel sock problem. I would start with seeing if it fires when you feed it fuel and go from there. |
#8 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
sub'd
#11 | |
As for fuel, I got some gas last night, but the battery was too low as I left the ignition in accessory from the previous day so I left the truck on the trickle charger last night (don't currently have a heavy duty charger). We'll find out today if it fires |
Nope, its mostly there, all that's left is A/C, interior, exhaust (open headers right now), bed wood (bed is on with plywood temporarily), new tires and eventually I'll re-gear the rear end.
#13 |
#14 | |
I hope it fires up for you. Easy fixes are my favorite kind. |
#15 |
![]() Join Date: May 2013
Total agreement
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#16 |
#17 |
Update:
Got everything working just fine and went on my first successful test drive last night (besides the rear end needing to be regeared to match my transmission and the alignment being so far off that it throws you when driving over a man hole, it rides half decent...Next stop: Alignment/muffler shop The fix(es): No start-Turns out the truck was just out of gas, but I guess it happened for the best, someone was looking out for me because the steering issue was just plain dangerous, I'm glad it stalled and wouldn't start. The steering-I started the process to replace the steering box last night when I noticed the screw that holds the rag joint on the box side was totally loose. I tightened it down and all the slop and noises went away. Thanks for the help guys! |
#18 |
Where's my beer?
Glad you got it worked out. Yeah, I'd say the running out of gas was the big guy looking out for you!
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
#19 |
If you ran it outa gas you should check your fuel filters.
That's a good way to suck up any dirt in the tank. I learned it's too easy too install the inner tie rods the wrong way. Do yourself a favor and double check that your inner's have the stud facing forward. If they are facing rearward it will make your steering real weird. You certainly had luck on your side there. Just for giggles I would check all the steering fasteners up there after I wiped the cold sweat away.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#20 |
I'm glad it's working for you. Let us know how it rides after the alignment.
#21 | |
