![]() Join Date: Feb 2009
Throttle cable replacement, and what's the deal with the ball stud?
This is the carb. side of the throttle cable off my 71. It's probably factory. I believe this was on all 71-72 350-402 2WD C-10-30 trucks.
Apparently the stud pushes into place. I'm unable to confirm via the web (no phone call) that any replacements come with this stud. Can anyone shed some light on this? In other words, can you recommend a good cable with/without stud, are the studs separate, involves a modification at the carb., cut the old one out, etc.? I'm trying to keep the truck as original as possible. Thank you. http://www.usa1industries.com/1971-7...cable-2wd.html https://www.brotherstrucks.com/71-72...tinfo/TCA0010/ http://www.classicparts.com/1971-72-...B#.WJuOam8rLcs ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Throttle cable replacement, and what's the deal with the ball stud?
"I pawned my Hanso" "Hold my beer, Watch this" |
![]() Join Date: Jul 2016
That carb ball stud is retained by the spring clip that is around the end of the cable, just pull it out with a pair of pliers, put the nut back on it first so you don't damage the threads, its actually easier to remove the cable with the ball stud hooked to the carb linkage by levering it off with a screwdriver.
#4 | |
