55-56 with Camaro clip front tire size
Can you tell me what size tire you are able to run on the front with a second gen Camaro clip ? What size rim , 15" 18" , width, backspace etc. Any info appreciated pics even better . Thanks
![]() Join Date: Oct 2016
Re: 55-56 with Camaro clip front tire size
#3 | |
What is your width and backspace? |
The Fronts are 18X8.50 with 4.5 backspacing 5X4.75 bolt pattern.
The Rears are 18X9.5 with 5.25 back spacing 5X4.75 bolt pattern. On the rears if you are running the Camaro rear end 60", wheel mount to wheel mount, you need 4.25 back spacing... that took some time and effort to figure out!!! I'm going with a Ford 9 inch so it wasn't important to me, but I bought some one inch spacers and my wheels fit perfectly! Also the stock tires are 27 inches tall so I did tubular control arms with 1 1/2 inch shorter springs and 2 inch drop spindles. ![]() ![]() |
![]() Join Date: May 2012
can you explain this better I am ready to buy wheels and tires now
Yes the springs and spindles are installed in the pictures, mine is top of truck frame even with the Nova top of frame. I'll get you some frame pictures tomorrow
