Old 02-08-2017, 08:55 PM   #1
1968vetL-71
Junior Member
1968vetL-71's Avatar
Manual Tilt column for 76'. What years?
Hey everyone. I tried researching this several times. I'm converting a 76' auto to manual and i'd like to find a 4spd/tilt column (cruise would be nice). What years are a direct bolt in? I'd rather not mess with wiring pinouts or intermediate shafts so any and all information would be greatly appreciated.
From what I found 73-77? I can use up to 83 but swap shafts and re pin wiring if need too be?
Thanks again everyone!!!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 02-09-2017, 03:38 PM   #2
barry1982
Re: Manual Tilt column for 76'. What years?
Hi There,
I'm not sure about your area... but up here finding a 4-speed truck tilt column
is like trying to find hen's teeth..... I converted my 82 to a 4 speed.... but just continued using the original auto /tilt column. Took off the auto shift lever.
barry1982 is offline   Reply With Quote
Old 02-11-2017, 02:40 PM   #3
1968vetL-71
Junior Member
ya, they are a bit harder too find, but plenty out there.
Let me know if anyone has any more info on this stuff.
Thanks!!!
Old 02-11-2017, 05:17 PM   #4
El Dorado Jim
Originally Posted by barry1982 View Post
Hi There,
x2, I couldnt find a 4 spd tilt , just make sure you know what year you get one out of, the keyed ignition part is different on some years,there are two different ones and they dont interchange if you need to buy a replacement (they are available at the auto parts store)I think 73-79 are the same electrical connections...and have you had a tilt come loose ? you can tear into them and then use locktite on the four screws that keep it tight
El Dorado Jim is offline   Reply With Quote
