Starter
I have switch from manuel transmission to automatic on my 67 truck.
The engine is a 305 smallblock and the transmission 350. Need some advice on which starter I need? |
![]() Join Date: Apr 2013
Re: Starter
If you starter is fine I think all you need to do is get a different nose cone for the starter you have or go to parts store and tell them you need a starter for a small block Chevy with an automatic transmission.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
Re: Starter
[QUOTE=BlueBullet;7853005]If you starter is fine I think all you need to do is get a different nose cone for the starter you have or go to parts store and tell them you need a starter for a small block Chevy with an automatic transmission.[/QUOTE
He's time has passed. I need a new one. Thanks |
Re: Starter
you will need the one that bolts to your engine, not the bell housing, you will need the two starter bolts also, they are knurled bolts especially for starters, the auto parts store will have them, and you may have to shim your starter...the starter should come with instructions....
#5 | |
Re: Starter
Thanks |
Re: Starter
I have been searching all over the internet stores, and it's getting me more and more confusing.
I don't know what year my engine is (probably late 70) My old starter has 3 bolt holes and it's a Delco Remy 1107497, and when I thought I have spotted the right starter (new manufacturing starte) it's not referring to this number. I have send a message to Delco Remy, but they don't answer me. Here in Sweden the auto shop seller said I need the Chevy 305 350 454 Mini Racing PMGR Starter High Torque 6449 by URQS. Do you agree? |
Re: Starter
you cannot use your old 3 bolt starter with an automatic, you will have to get a 2 bolt starter that bolts to your engine...and you dont need the high torque mini starter, any starter from 73-mid eighties will work....for small or big block and like i said before, you will need the knurled starter bolts,you can get the starter and bolts thru Summit racing
#8 | |
Thanks Posted via Mobile Device |
