Turbo 400 no engine braking in 2nd gear
Anyone have experience with a broken plastic servo piston causing no engine braking in 2nd gear?
Was the fix as easy as dropping the valve body and replacing the servo piston and sealing ring with a metal one? It's in my sons 1986 c20 Scottsdale with a 350/th400 combo and only 56,000 original miles. 400s didn't change much between body styles (well except the cheap piston!) Thanks!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: Turbo 400 no engine braking in 2nd gear
Really? Nobody?
Post Whore
![]() ![]() Join Date: May 2015
Clinebarger would be the man to answer your question. Give him time
In drive range-second there is no engine braking because power is driven through a one way clutch. In manual second it brings on the band to help hold the sun gear and give engine braking.
So yes, a bad servo piston could cause no engine braking but still work in second gear.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#5 | |
Should be a simple driveway fix right?
#6 | |
It's the Plastic 3rd Accumulator Pistons that break, Not the Intermediate "Brake" Band Servo Piston. Never seen a Plastic Servo Piston in a TH400. A broken Accumulator Piston will allow L2 oil to leak into the 3rd/Direct clutch circuit & prevent the Servo from applying the Band. |
#7 | |
Yep it's in the Valve Body. It's not hard at all, Careful not to mangle up the Governor Tubes!
