Old 02-09-2017, 12:44 PM   #1
C1ph3r
CPP Front Shock Bracket Install Help
Hey guys. Just picked up some CPP Front shock relocation brackets for my 70 C10. Running this because... bags.
Any one have pics of them installed that would be great.
I have seen an image that showed them sitting, not really installed, on top of the frame rail.
Do I just line up the mounting point for the shock directly above where the factory shock mount is?
Here is a pic of what they are.
1970 C-10 LWB Build Thread
C1ph3r is offline   Reply With Quote
Old 02-09-2017, 01:20 PM   #2
PGSigns
PGSigns's Avatar
Re: CPP Front Shock Bracket Install Help
I would line them up using the shock at ride height. That would give you the best place to start.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-09-2017, 01:24 PM   #3
C1ph3r
Jimmy
I assume they need to be in a place where the shock is as vertical as possible?
thanks,
A.W.
Old 02-09-2017, 09:27 PM   #4
PGSigns
PGSigns's Avatar
The angle of the lower mount will place the shock at the angle it has to be. Ride height places it in the position it will spend most its life. Bolt the new top mount on the top of the shock and slide it up on the frame. That will be the best spot for it.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-09-2017, 10:20 PM   #5
C1ph3r
10-4 thanks.
Old 02-10-2017, 03:43 PM   #6
bs46488
I did mine with a second pair of hands so that we could make sure everything was inline.
I used a pair of vise grips to hold it in place.
I had to drill some holes and also notch my inner fenders for final install
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 02-10-2017, 06:08 PM   #7
C1ph3r
sounds good. do you have any pics?
Old 02-10-2017, 10:59 PM   #8
suville
suville's Avatar
Hmmmm ? watchin this Thanks
suville is offline   Reply With Quote
Old 02-11-2017, 01:14 AM   #9
jweb
jweb's Avatar
I found this picture, hope it helps
jweb is offline   Reply With Quote
Old 02-11-2017, 08:56 AM   #10
C1ph3r
It does. Thank you. Looks like I will for sure need a right angle drill. I can't tell but is that the driver side or passenger? I think it's passenger.
Old 02-11-2017, 02:03 PM   #11
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Shocks are to the rear of the arms, so that is the driver side.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-11-2017, 03:49 PM   #12
C1ph3r
Duh. Wow I knew that. I feel dumb. Thanks.
