Old 02-09-2017, 01:20 PM   #1
FstCarsNGuitars
FstCarsNGuitars's Avatar
TCC switch for ls swap 47-53
Hi guys, I'm currently working on my second LS swap vehicle and this time its for my '53 shortbed. When I did my last conversion on my '70 nova I had to incorporate a brake/tcc switch for the converter lockup, which was relatively easy to install because I used the stock brake switch bracket. Being that the '53 brake master and pedal are mounted on the frame rail I'm wondering what any guys out there with 47-53 ls swaps did for this switch as far as mounting is concerned. I'm trying to brainstorm ideas and having a hard time deciding on how and where to mount the switch. Any help is greatly appreciated!
1967 LWB fleetside 283ci 4spd granny,
1968 SWB fleetside 454 th400, 5 lug disc
1970 SWB Stepside 350 th400
1953 SWB 1/2 ton LS 6.0 4l80e
FstCarsNGuitars is offline   Reply With Quote
Old 02-09-2017, 01:32 PM   #2
rstrittmatter
Re: TCC switch for ls swap 47-53
http://lt1swap.com/wiringharness.htm
Read the part about using a relay feed from the existing brake light switch.
May work for you.
Richard
rstrittmatter is offline   Reply With Quote
Old 02-09-2017, 01:38 PM   #3
FstCarsNGuitars
May work for you.
Richard
That actually looks like the best solution, thanks for the info!
