02-09-2017, 02:11 PM | #1 |
Boyd's rear tank. Need a hitch
Who has ran a similar setup?
The tank mounts to the inside rails and wondering if I am going to run into and issue with all I am seeing with how hitches mount. Hidden hitch has a better mount from pics but can't run it with bumper setup. Need a below bumper setup. Anyone have pics of similar rear tank and hitch. Thanks |
02-09-2017, 02:22 PM | #2 |
Re: Boyd's rear tank. Need a hitch
I'll get a pic later but I had a hitch made.. pulled a few vehicles on a trailer and no problems..
02-09-2017, 08:06 PM | #3 |
02-09-2017, 09:42 PM | #4 | ||
"I ain't nobody, dork."
Give it time... It hasn't even been 24 hours.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-09-2017, 09:55 PM | #5 |
subscribed ...ill be interested to know i will be installing a Boyd tank and would like the hidden hitch option i had one built for my step side that has a tank from lmc between the rails id rather do the bolt on
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-09-2017, 10:02 PM | #6 |
I used a boyds tank with the cpp hidden hitch. It all fits. I did put my tank between the frame rails. I will post a pic later.
02-10-2017, 05:56 AM | #7 |
I have looked at this several times but due to the bumper I am using I can't use a hidden hitch. However, the hidden hitch bolts the way I need one to work.
02-10-2017, 09:08 AM | #8 |
pictures of your bumper??? please
02-10-2017, 09:34 AM | #9 |
Next time I have it unwrapped I will take pics. It's a shaved bumper. No bolts shown and a shorter molded in tag area. I had it powdercoated as well. Wish I could recall who makes it. But it also moves the bumper in closer so you do not need the rock guards on the bumper brackets
02-13-2017, 02:39 PM | #10 |
the boat guy
My boyd tank is sandwiched between my hitch and the bottom of the frame. I have a regular hitch with the center section rotated so that its upside down and goes through my license plate on my sport bumper. I'm sure I could flip the center section and have the hitch below the bumper.
