![]() Join Date: Feb 2009
Parts ID anyone?
1971 C10 402:
Pic 1: Any ideas what this retainer is for factory? My 72 has one as well. It's being used for an 8-10 gauge wire that runs to the front for I couldn't tell you it's nasty outside. It's not relevant to the 71 anyway, because the 72 doesn't have the same configuration through the firewall......That make sense? ![]() Pic 2: What's this section called? Might offer a label for the cross member, and at some point I'll have to remove it any how. Thank you ![]() ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Parts ID anyone?
#2 carrier bearing
![]() Join Date: Feb 2004
or driveshaft carrier bearing center support cushion
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
Wiring harness, 71 GMC K25
My 72 (C20) has that same brake booster support attached to the same E-brake stud, where the retainer is. At least I think it's a brake booster support. Too nasty outside to check. Perhaps that support is for medium trucks? My 71 C-10 doesn't have one. Know what the retainer is for?
I guess that make the cross member the "driveshaft carrier cross member". Just taking a shot here...................Green til educated. Thank you.
Sorry, should have been more specific. The clip holds the wiring harness that is hanging below it. Harness was removed from the clip before the pic was taken. You're right, that's the booster support, don't know about 2wd but the 4wd's have the support rod for the booster.
#8 | |
