Old 02-09-2017, 09:23 PM   #1
Hrothgarz
1967/1972 350 swap
Im looking into buying a 1967 k20 sitting on a 1972 k10 frame. it has no engine just a 3 speed trans 4x4. i would like to swap the 3 speed with a 4 or 5 speed and drop a 350 engine in the truck. i don't have a ton of money to play with so im just looking into what would be easiest meaning least amount of fabrication to make it fit and cheapest. thanks for the help guys!
Hrothgarz is offline   Reply With Quote
Old 02-09-2017, 09:32 PM   #2
saxart
saxart's Avatar
Re: 1967/1972 350 swap
If you could find an original SM465 (4-speed with a granny 1st gear) you could always swap that in. The 350's were an option on these trucks, so the engine part should be easy with the right mounts.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 02-09-2017, 09:44 PM   #3
Hrothgarz
alright know a year/vehicle to look at to find one 4x4? and what transfer case to come with it? Im assuming the 205? thanks for your help by the way
