Old 02-09-2017, 09:58 PM   #1
18Z
18Z's Avatar
Rearend help
Can anyone ID this rearend and why the wheel cylinders don't come out without what looks like having to pull the axles and if so how? I have attached photos of everything.
18Z is offline   Reply With Quote
Old 02-09-2017, 10:00 PM   #2
18Z
18Z's Avatar
Re: Rearend help
Forgot to mention it is a 1971 GMC K1500
Old 02-09-2017, 10:25 PM   #3
B. W.
B. W.'s Avatar
Re: Rearend help
looks like a dana 44
B. W. is offline   Reply With Quote
Old 02-09-2017, 10:38 PM   #4
18Z
18Z's Avatar
Re: Rearend help
I have a Dana 44 in the front but this is the rear but it doesn't have the 60 cast into it where I have a 44 cast into the front.
Old 02-10-2017, 12:10 AM   #5
18Z
18Z's Avatar
Re: Rearend help
Any help anyone!!!
Old 02-10-2017, 12:31 AM   #6
Shinysideup
Shinysideup's Avatar
Re: Rearend help
If they wont wriggle out sideways you could loosen or remove the backing plate bolts so it moves away at top.
BTW,Ive never seen an axle that looked doubled-up on the flange and with those welds?
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 02-10-2017, 06:58 AM   #7
Bigdav160
Bigdav160's Avatar
Re: Rearend help
Definitely a Dana.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-10-2017, 09:13 AM   #8
Mike C
Mike C's Avatar
Re: Rearend help
It's either a 60 or a 44. If you have a 44 in front then the cover in the rear should be larger if it's a 60 and same size if it's a 44.
The semi-float Dana 60 is fairly uncommon found in big blocks in 67-68, but a Dana in the rear of a 1/2 ton after '68 is unusual as well and my guess is it was swapped from something else.
44's were found in both ends of 67-68 4x4 IME and probably more of those than 1/2 ton big block trucks so 44's more common.
So compare cover size and you tell us what you have!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-10-2017, 11:38 AM   #9
B Myers
B Myers's Avatar
Re: Rearend help
I agree, there is an extra metal backing on the axle flange that may have been added due to some type of stud failure and that was a way to save the axles. The extra space they take up keep the cylinders from coming out, I have never seen a standard axle that you couldn't get the cylinders out.
B Myers is offline   Reply With Quote
Old 02-10-2017, 08:02 PM   #10
18Z
18Z's Avatar
Re: Rearend help
Thanks for all the responses, I will try loosening the backing plate tonight to try and remove and will post what happens.
Old 02-11-2017, 01:43 AM   #11
18Z
18Z's Avatar
Re: Rearend help
Went to loosen the backing plate and noticed the PO had welded it in place, so I had to pull the axle to get it off.
Old 02-12-2017, 04:30 AM   #12
Mike_The_Grad
Mike_The_Grad's Avatar
Re: Rearend help
Lame! Did you change axle seals and bearings while you were in there?
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
Old 02-12-2017, 10:22 PM   #13
18Z
18Z's Avatar
Re: Rearend help
Yes I am going to.
Old 02-13-2017, 12:17 AM   #14
El Dorado Jim
Re: Rearend help
I agree something weird with those axles...
El Dorado Jim is offline   Reply With Quote
Old 02-13-2017, 12:19 AM   #15
El Dorado Jim
Re: Rearend help
that is weird, you may want to replace those axles, something isn't right with those doubled up welded flanges...
Old 02-13-2017, 01:05 AM   #16
Mike_The_Grad
Re: Rearend help
I just replaced the seals and bearings on my 72 c10 12-bolt rearend,5 lug. I hadn't planned on doing it,but while I was doing a complete overhaul of my rear drum brakes I noticed both sides seals were leaking. One funny thing about the job,IMO, is I had to borrow a slide hammer from Autozone for the bearings, or at least I thought I did...after the seals were out and I had the slide hammer setup, I went to pull back on the hammer and it caught the lip of the bearing race and the bearing just fell out of the axle tube! So I went to the other side and I was able to slide out the bearing with my fingers. They seemed to be in ok condition, the outer races were a little discolored but no broken pieces or anything. The Timken bearings I ordered went in nice though, solid and true. Same with the National seals.(the seals were a PITA to seat though even with the right installer.) But I got it all done and am glad that task is over with. Good luck with yours. It seems you already have an interesting setup, and I hope it goes smoothly for you.
