Old 02-09-2017, 10:26 PM   #1
reed62
reed62's Avatar
Steering Column distance from dash opening
Hey all,
I had a question about the distance between the opening for the steering column in the dash and the cone shaped housing near the top of the column. I know this could be a way to add more space between the seat and passenger to the steering wheel. I've seen some pictures that show about an inch clearance between the bottom of the "cone" and the opening in the dash. I know that if you have a column shift, that part will rotate during gear selection. I have a floor shift so it will not be a factor.
Thoughts?
Randy
reed62 is offline   Reply With Quote
Old 02-09-2017, 11:05 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Steering Column distance from dash opening
If you are willing to shorten the steering shaft between the column and rag joint, you can move the column as close as you can. I positioned my Ididit column to 1/4" at the top of the column cover and the dash.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-09-2017, 11:21 PM   #3
mehoff400
heres a good write up
http://lugnutz65chevystepside.weebly...ification.html
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 02-09-2017, 11:41 PM   #4
reed62
reed62's Avatar
I'm using 2 borgeson joints and a custom length DD shaft. I haven't drilled any holes in the column yet to mount it with nutserts, so I am just getting an idea of what will work best for me. I'm thinking a 1/2 inch to an inch from the opening.
Thanks all
Old 02-10-2017, 12:29 PM   #5
vin63
vin63's Avatar
Originally Posted by reed62 View Post
I'm using 2 burgeon joints and a custom length DD shaft...
That makes it a lot easier. I run one joint at the column end - DD shaft - rag joint at the steering box.
Old 02-10-2017, 01:32 PM   #6
reed62
reed62's Avatar
I thought about using a rag joint but don't want to have to buy one of those + a shaft with a flange and then a borgeson joint or a slip joint on top of that. I'd like to keep it simple with as few connection points as possible. I ran two borgeson joints on my last project (50 Ford pickup) and didn't notice any vibration or buzzing in the steering wheel when driving.
Old 02-10-2017, 05:28 PM   #7
forestb
forestb's Avatar
I have seen people talk about this but I don't understand the point. It would seem that if the steering column is shorter the wheel would be closer to your lap. I am 6 ft 4 and the problem I had with the stock wheel was that it was to low and close to the top of my legs. If it were shorter it would be even tighter under the wheel.
forestb is offline   Reply With Quote
Old 02-10-2017, 07:52 PM   #8
vin63
vin63's Avatar
IIRC, Reed62 will be installing an aftermarket tilt column. The other route that many people use to avoid that issue is to go with a smaller diameter steering wheel. Our trucks, especially 60-63 knee-knocker cabs, are not very ergonomically accommodating for tall people.
Old 02-11-2017, 07:09 PM   #9
Lugnutz65
Lugnutz65's Avatar
I've done this mod when I upgraded to PS. I wanted to accomplish 2 things. I wanted a column that would telescope to improve safety and I also wanted the wheel a little closer to the dash.
True, moving the wheel closer to the dash will make it lower too, but maybe only 1/2". If that 1/2" is a deal breaker then just get a smaller diameter steering wheel. Moving the steering wheel closer to the dash can also be accomplished by using a SW with less dish.
I shortened my column and added the DD telescoping section because I had all the pieces and it seemed like a fun project.
LINK to the DIY steering column modification on my BLOG.
Rough measurements show that that I was able to move the SW 2 to 2.5" closer to the dash by sliding the column 3" (because it's at an angle). It lowered the SW about 1/2". Still very comfortable for me.
BEFORE
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 02-11-2017, 07:10 PM   #10
Lugnutz65
Lugnutz65's Avatar
after
