02-10-2017, 09:26 AM | #1 |
Pics of stepside taillight wires
Anyone have a pic of the wires/plug for a 67-72 stepside taillight(s)?
Mine seems to have 2 wires on each plug, but there is a mystery third wire that looks to be cut. Trying to find out what a stock plug and wiring harness looks like. Also, if anyone knows what color wire goes to what, that would be great. Trying to figure out an electrical issue in another thread. Thanks!
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
02-10-2017, 01:46 PM | #2 |
laying low
Re: Pics of stepside taillight wires
Good question.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-10-2017, 01:47 PM | #3 |
Nope, I have a separate wire for that. And both taillight plug has 3 wires.
02-10-2017, 03:35 PM | #4 |
Msgt USAF Ret
Here's your tail light wiring harness.
Wire colors: Brown ---tail lights yellow ---left turn/left brake dark green----right turn/right brake light green ---reverse lights. Main connector is on the firewall behind the distributor, then a mid frame connector and finally a rear frame connector.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-10-2017, 03:44 PM | #5 |
Thanks Vette Vet. I'll have to compare that to what I've got.
05-16-2017, 02:33 PM | #6 |
bump. anyone have a pic of where the taillights should be grounded on a stepside? having an electrical issue with mine where the taillights don't work when the headlights are on. trying to make sure its not a bad ground near the taillights. thanks!
05-16-2017, 03:39 PM | #7 |
Watch out for your cornhole !
The taillights ground through their bodies and the two studs where they bolt to the bed bracket. There is no separate wire.
05-16-2017, 03:42 PM | #8 |
ok, thanks
05-17-2017, 12:07 AM | #9 |
laying low
I went out and took pics of my light harness on the 69 stepside. It is as factory, unmolested.
The 3rd wire from the left side tail light is actually the lead to the license plate light. Due to low light it may be hard to see but mine is still in place and correct. Have a look.
05-17-2017, 08:20 AM | #10 |
thanks! I have LED brake lights so I'm not sure how the previous owner hooked them up. Although, it was working fine when I bought the truck originally so I feel it's got to be a bad ground somewhere.
05-17-2017, 01:13 PM | #11 |
It's been my experience on stepsides that the ground circuit fails where the studs on the back of the light bolt to the brackets. Sometimes it takes some corrosion removal and fresh toothed washers under the mount nuts to get a reliable ground.
05-17-2017, 02:00 PM | #12 |
thanks! I'll give that a try
