1971 K20 Long Bed Brake Line
Hi, fellas
I bought some brakelines from Classic Ind. And i cant seem to figure out how they actually lay in. All the pictures I can seem to find on here have the control arm c10 sytle of brake lines. Im looking for some pictures for the 4x4 K20 71-72 leaf spring models. Thx ![]() |
Re: 1971 K20 Long Bed Brake Line
These are the best I have, if you can zoom in you can sorta see. The red one is a 70 K20, green one a 71 K25. I bought Inline Tube lines & they were so far off I bent my own.
OK, thx. If anyone else out there has anymore much is appreciated.
The pic above showing the line and hose is actually the fuel line from inside the cab to the hardline that runs up to the front.
If I can get outside later today, I'll climb under my '72 K2500 and take pics of the brake lines. Do you need front, rear or both?
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#5 | |
found a couple of pics of the rear brake line removed. You can see a hard "S" bend on the left side of the first pic. That's the same "S" you see in the fuel line pic to give a little perspective. I know, not much help.
Hey, I found some good pics if you still need them:
Thank you, again. I found what i was looking for. Or basically figured it out.
