Old 10-15-2003, 08:47 PM   #1
Mark70Z
2WD vs. 4WD Rally Wheels
Have a question.. Is the 2WD Rally Wheels the same as a 4WD Rally Wheels?? Are they 15X8, or are they a different size? I know the caps would be different, but would the size be different??
Please help!
Mark70Z is offline   Reply With Quote
Old 10-15-2003, 09:23 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
2 wheel drive 15x8 wheels are 5 lug and have 4 1/4 inch backspacing
4 wheel drive 15x8 wheels are 6 lug and have 4 inch backspacing.
Old 10-15-2003, 09:24 PM   #3
Tx Firefighter
Forgot to add, some 2 wheel drive rally wheels are 7 inches wide too. Typically found on vans. They work very well under the front end of a deeply lowered truck.
Old 10-15-2003, 09:38 PM   #4
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
What about 2wd 6 lug rally wheels?
chevy_fatman is offline   Reply With Quote
Old 10-15-2003, 09:45 PM   #5
Mark70Z
Right...what about the 2WD 6 lug rallies? The ones that I'm looking at are 6 lug. The fellow that is selling them said they were from a 2wd. Would they be 7" or 8"?
Old 10-15-2003, 09:51 PM   #6
Rod
If there 6 bolt pattern there probably 8 inch and originally from a 4x4.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-15-2003, 09:52 PM   #7
Tx Firefighter
I don't know of any 2 wheel drive truck built with 6 lug wheels since 1970. 71 went to 5 lug and all 1/2 tons stayed 5 lug up till 1999.
Rally wheels on trucks began in 1973.
No such animal as a 2 wheel drive 6 lug rally I've ever seen or heard of. Of course, everyone has seen the 4 wheel drive wheels installed on 1970 and earlier 2 wd trucks.
Old 10-15-2003, 10:13 PM   #8
chevy_fatman
Where's my beer?
Mark70Z, those wheels most likely will fit your truck, if it has 6 lugs, here's a pic of a rally in my '70.
Old 10-16-2003, 12:23 AM   #9
Shane
Shane's Avatar
No such thing as a 6 lug / 2wd rally, although the 6 luggers WILL fit '70 and earlier 6 ug trucks ... GM didn't offer rally wheels on our trucks.
All 2wd rally's were 5 ug and all 4x4 rally's were 6lug.
Shane is offline   Reply With Quote
Old 10-16-2003, 01:06 AM   #10
dtlilly
dtlilly's Avatar
This discussion is really interesting. Here's another Q, when did they start making rally wheels for the 8 lug trucks?
dtlilly is offline   Reply With Quote
Old 10-16-2003, 01:19 AM   #11
paintpyro
paintpyro's Avatar
Is there a way to make any other center cap fit on a 6 lug 4x4 rally on a two wheel drive?
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 10-16-2003, 09:04 AM   #12
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Slide in from the rear style. Like a Chrome crager cap.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 10-16-2003, 06:44 PM   #13
Pilgrim
Check Coker Tire catalog page 29, Pickup Rallye pre '71. Chrome wheels 15 x 7 were $74 @ for my '69 stepside. Check page 31 for bow tie caps.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 10-16-2003, 08:37 PM   #14
Mark70Z
Ok...then.. If no 2wd rallies... What is the bore size of the center hole??? It should be different for 2wd and 4wd. I know this is the way it is on my car. The car has a small bore size hole. Also, is the 3/4 ton and the 1/2 ton the same bore size hole??
Old 10-16-2003, 10:33 PM   #15
Tx Firefighter
Dude, you're not making sense.
There are 6 lug rally wheels. They came off of a 73 up 4x4. Period.
There are 5 lug rally wheels. They came off 2wd trucks and vans 73 up. Period.
If some dude told you he had a set of 6 lug 2 wd rallys, he's wrong. He has 4x4 wheels. They fit 6 lug 2wd trucks just fine.
What does center hole bore have to do with it? And how does your car come into play here?
See the pic below? 6 lug 4x4 rallys on my 2wd truck.
Old 10-17-2003, 10:25 AM   #16
HuggerCST
HuggerCST's Avatar
Here is a set with convex spot mirrors glued on them. The mirrors appear as chrome. Bad pic, but you get the idea.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 10-17-2003, 02:00 PM   #17
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Here's a side shot of my 4x4 rallies!
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 10-17-2003, 03:33 PM   #18
Like was mentioned you can cover the holes...Either cut a piece of sheet metal, then get a new sticks, or do the spot mirrors.. 4 mirrors at Walmart and some JB weld silcon sealant. less than $10. They gicve a nice effect too.
Palf70Step is online now   Reply With Quote
