Old 02-10-2017, 09:34 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up What direction...
I went to the local LQ yard today to find some much needed parts for my daughter's 2000 S10. I found most of what I wanted and then bam!
I got side tracked. Started hunting a mirror for the Ramp Rat like I have in my 71. I found several but only 2 worked. I got the senor's also it's only a 4 wire hook up. I took a small 12 volt battery with me to check them. It was nice having it so I don't have to drive the hour drive back to return them.
When I get the Ramp truck windshield replaced I'll be mounting it.
I also picked up some squirters off of a couple of late Envoy's rear glass wipers. They just clip over the arm. These will also go to the ramp truck wiper's to get a full swipe of water when needed. Tahoe's, Suburbans anything with rear wiper with washer should work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-10-2017, 10:39 PM   #2
Shinysideup
Shinysideup's Avatar
Re: What direction...
Pics and location of those sensors for the mirror?
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 02-10-2017, 10:58 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What direction...
They are up front on the radiator supports. Most are center of the vehicle but I found a couple mounted on the drivers side today.
Generic pictures. Most of the ones i HAVE ARE LIKE THE SECOND PICTURE.
Old 02-10-2017, 11:09 PM   #4
Andy4639
Old member
Andy4639's Avatar
I just looked and O Reilly carries both the senor's.
The first one is the one I get.
http://www.oreillyauto.com/site/c/de...patibilityTab_
Old 02-11-2017, 01:55 PM   #5
Shinysideup
Thanks Andy, I think this will replace the crusty mirror I have.
._____________
