Old 10-15-2003, 09:10 PM   #1
dion
72 Cheyenne
dion's Avatar
welp, I found out whats wrong with my engine today..
nothing! I finally broke down and took it to a speed shop. they said everything was good except for my HEI and timing, the carb needed some dialing in. they gave me the dyno tune and I have to say this is the best my truck has ever ran, finally! my stock HEI just isn't cutting the mustard so I'll be replacing it soon and I should be good to go. I guess the engine was just totaly out of wack all this time.
They also did two dyno pulls, 400 HP at 5800 RPM
the shop is called JBA Racing, heres the link for you so cal guys
http://www.jbaracing.com/index.htm?dyno.asp~mainFrame
they said I had a bad ass small block and something about if this engine was in a Camaro......
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 10-15-2003, 09:14 PM   #2
rage'nrat638
rage'nrat638's Avatar
THATS THE COOLEST.....
glad to see u got it worked out
rage'nrat638 is offline   Reply With Quote
Old 10-15-2003, 10:05 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
B!tchin!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-15-2003, 10:08 PM   #4
Iron-Butt
454 club
Iron-Butt's Avatar
Nice.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 10-15-2003, 10:27 PM   #5
dinnut
dinnut's Avatar
thats a pretty big number. 400.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-15-2003, 10:40 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
400 HP...sweet!
I would imagine that is corrected for at the flywheel....because if it was rear wheel you would have somehting like 500 flywheel horsepower.
Glad you got the problem sorted out
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-15-2003, 11:10 PM   #7
Hooter
My other Love
Hooter's Avatar
was that at the rear wheels?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-16-2003, 12:38 AM   #8
Linus0014
Guest
Posts: n/a
Does this mean you'll be back to the So Cal Truck Club meetings?
Old 10-16-2003, 01:11 AM   #9
bigjimzlll
bigjimzlll's Avatar
Hmmmm....you must have some kick azz heads..very nice
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-16-2003, 01:14 AM   #10
jorgensensc
jorgensensc's Avatar
How much did the dial in and dyno cost??? If you don't mind me asking.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-16-2003, 01:34 AM   #11
dtlilly
dtlilly's Avatar
Dion, what size double hump heads are you using?
dtlilly is offline   Reply With Quote
Old 10-16-2003, 09:03 AM   #12
bigjimzlll
bigjimzlll's Avatar
Hes using #186 castings with 2.02-1-6 SS valves. A real nice bowl port job..screw in studs..back cut valves..spring pockets cut to accept 1.45 springs..( I built them... )
Anderson,CA
Old 10-16-2003, 10:06 AM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
Either way, 400 HP is great! Interested in also hearing what the dyno tune costed. Surely it is money well spent.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-16-2003, 10:30 AM   #14
dion
72 Cheyenne
dion's Avatar
The Dyno Tune costs $120 for 1.5 hours plus parts if needed, I didn't need anything but the HEI, that's next week.
Man I wish the HP was at the wheels, 400 at the flywheel, my torque was lower that I hoped though, around 330-350
JBA was great, they really knew what they were doing and didn't try to jerk me around at all and didn't try to sell me anything. I figure any place that can build a 9 second 305 must have something going on.
Another board member Smitty also had good dealings with JBA
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 10-16-2003, 11:27 AM   #15
jorgensensc
Thanks for the info!!! I will be setting up an appointment soon!!!
Old 10-16-2003, 12:09 PM   #16
nate68
i wish there was a dyno up here in nor cal
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 10-16-2003, 12:11 PM   #17
dion
72 Cheyenne
dion's Avatar
where are you? I know of a couple up there.
Burnout
Idle
1972Cheyenne
1966/67Stouts
