02-11-2017, 09:16 AM | #1 |
Vent window seal
I'm replacing the vent window in my 70 C10 but can't find the seal material that goes in the window frame. This is not rubber it's a kind of cloth material. Does anyone know where to find it.
02-11-2017, 10:38 AM | #2 |
Re: Vent window seal
It's the Division Bar Channel. Most vendors have them. They don't cost much and are easy to install
02-11-2017, 10:46 AM | #3 |
X 2 on that, real simple.
02-12-2017, 09:16 AM | #4 |
I'm looking for the material tha holds the glass in the channel. LMC sells a rubber gasket but this stuff is a cloth type of material.
02-12-2017, 10:00 AM | #5 |
Rick4076
Is this what you are looking for? http://www.classicparts.com/1951-72-.../#.WKBoRsIzXIU |
02-12-2017, 10:25 AM | #6 |
^x2 You can also go to glass installer and they usually have it. The last time the guy just gave me a bunch said they don't use that much anymore.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
02-12-2017, 12:46 PM | #7 |
Active Member
It's called glass setting tape. I can't find my order details at the moment but I bought a 20' roll on eBay for like $16. You only need like 8 feet for both vents and windows, but the one local place that had it near me wanted a couple dollars a foot. It's kind rubbery. You form it along the glass then push it into the frame. It was a super tight fit so I used some winded to line it a bit. Then once it's in, it's wider than you need, so you just trim off the excess. The trickiest part I found was the corner of the vent glass.
David Larsen 1970 Chevrolet C-10 |
02-12-2017, 03:13 PM | #8 |
That,s the stuff glass setting tape. Thanks for the help guys I appreciate it!
02-12-2017, 03:27 PM | #9 | |
72 BB C30 Super LongHorn
What would be considered the correct thickness to use for 67-72 vent window installs?
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
02-13-2017, 12:32 AM | #10 | |
I would Measure the frame I.D. of the vent wing I was installing then measure the vent window thickness and go from there. Formula = Inside thickness of frame -minus-thickness of glass- divided by Two equals room for gasket |
02-13-2017, 12:19 PM | #11 |
Great advise thanks a lot!
