Old 02-11-2017, 11:39 AM   #1
5150
C10 Club Tennessee
5150's Avatar
1967-1972 Steering Column in a 1964
I'm attempting to put a 67-72 column in my 1964 service truck. I'm going to try to use the original steering wheel, but for some reason there is an awful lot of play in the wheel. I can move it up an around freely.
Is there an adapter that can mate the two plugs together?
What's the deal with the dealer optioned emergency flasher?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 02-11-2017, 01:28 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1967-1972 Steering Column in a 1964
Are you saying the steering shaft splines on the column are smaller than the splines in the steering wheel?
Or is the shaft itself moving around in the column?
Old 02-11-2017, 08:58 PM   #3
DPowers
DPowers's Avatar
Almost positive that M&H makes an adapter.
http://www.wiringharness.com/
Correct that the hazard is in the "middle" of the wiring so to speak.
DPowers is offline   Reply With Quote
Old 02-11-2017, 10:00 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
That's the adapter I got!^^^^^^
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-11-2017, 11:36 PM   #5
Bryan, one of the things that made me change to a 69 column in my 64 was the difference in how the turn signal canceling cam is. where it goes thru the steering wheel is off by about 60 degrees. If you are going to use the original wheel you may have issues with the horn/turn cam.
I ended up splicing in the 64 wire ends to my 69 column wire, then plugged it into my new dash harness. Most of the newer harnesses from what I have seen have a generic connector (similar to the ones shown in the M&H link) replacing the original style connectors.
I also liked when I swapped columns I also changed the shaft so it would be collapsible (69/79 intermediate shaft) in stead of the ole sper checker shaft, which I think is slightly smaller in diameter that the one from the 69.
Old 02-12-2017, 01:30 PM   #6
vince1
I don't know about newer than 66 or 67 but the early ones needed a spring at the bottom of the column to keep the upper and lower bearings seated. Is your top bearing working as it should?
vince1 is offline   Reply With Quote
Old 02-14-2017, 11:19 AM   #7
5150
C10 Club Tennessee
5150's Avatar
So on the electrical side am I going to need these two to make this work?
Bryan
www.gmtruckshow.com
Old 02-14-2017, 01:33 PM   #8
That should do you Bryan.
Old 02-14-2017, 02:34 PM   #9
5150
C10 Club Tennessee
5150's Avatar
Good lord, who'd of thunk I'd have to spend $50 plus shipping on adapters to make a $50 steering column work. I should have gone tilt at this point.
Bryan
www.gmtruckshow.com
Old 02-14-2017, 06:41 PM   #10
You could have done like me and just cut the wires from the old column and spliced them into the 67-72 column harness. The colors match up so it isn't hard.
Old 02-15-2017, 12:31 AM   #11
66 C10 383
I was not there when my nephew had a mechanic friend of his swap in a 67 column. With that being said, I too asked about the wiring. He said they just repinned the 65 wires to the 67 plug in or something like that. I know he didn't need to buy an adapter plug.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 02-15-2017, 08:09 AM   #12
65chevysub
65chevysub's Avatar
I had a 72 tilt column put into my 65 Suburban, with a TH350, and was lucky enough to use my original deluxe steering wheel(the splines on the wheel and column matched). The only thing that doesn't work are the emergency flashers. I did have some issues of the tilt part coming a little loose after it was installed(1999), but the guy who installed it put some Loctite in there, and has been perfect ever since.
65chevysub is offline   Reply With Quote
