Old 10-15-2003, 09:30 PM   #1
Russell
Professional Grade
Russell's Avatar
What tells you that a lifter is bad?
Alo, pulled one of my lifters tonight to see if I can find that knock from my engine on the driver's side, that thing must have been changed out with the engine rebuild... I can still see machining marks on the sides of it... If one of these things is collapsed, or bad, what am I looking for? I'm just gonna assume on of the springs is bad...
Also, how tight is tight enough for the engine to run off those tappets? I know the way to tighten them, start the engine, slowly back off the bolts on them until you hear a ticking, then tighten it slowly till it stops, then give it 3/4 of another turn, but how tight is tight enough to start the engine without damaging it?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-15-2003, 09:52 PM   #2
Destructo
I woould turn them down 1/2 a turn rather than 3/4, that seems to work a little better and insures their not overtight. And what exactly are you talking about being too tight to start the engine? The lifter preload? If so don't go more than 3/4 turn, if you have to go further to stop the noise then something is wrong.
Destructo is offline   Reply With Quote
Old 10-15-2003, 10:06 PM   #3
Russell
Professional Grade
Russell's Avatar
What I mean is that I have taken my lifters out, so I have loosened those tappet things, how tight should I make them so I can start the engine later on without wrecking them
Old 10-15-2003, 10:57 PM   #4
Destructo
Oh I see what your talking about, talking about the rockers? Thats the push rod goes into and they rock on a stud and push the valve down? You will actually have to set the valve lash cold before you start the engine since you pulled the lifters. If you don't have a Haynes manual you should get one, it will be able to describe how to set the valve lash cold better than I could over the internet. You can run it like that but I don't trust my ability to get them just right like that so I just do that so the engine will run without harming anything then afterwards I adjust them using the running method.
Old 10-15-2003, 11:10 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Look on swervins's site, www.73-87.com. He has instructions for adjusting the valves:
http://www.73-87.com/garage/valvlash.htm
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-15-2003, 11:18 PM   #6
Russell
Professional Grade
Russell's Avatar
I gotta check that guy's site more often Mike has all the answers on that site, lol
Old 10-16-2003, 09:34 AM   #7
Slonaker
Slonaker's Avatar
Yep. Every time someone posts a queestion, I just say "look on Swervin's site."
Thanks Mike!
Slonaker
Stock '01 Silverado
Old 10-16-2003, 09:21 PM   #8
Russell
Professional Grade
Russell's Avatar
My lifters are all convex And in really good shape. I'm 90% sure that it isn't my lifters ticking... I am wondering if maybe those rockers arn't tight enough and one is ticking..
