02-11-2017, 03:24 PM | #1 |
basic tools to keep in truck
Hey folks,
I'm planning my road trip to SF to drive my new to me 1984 C10, it's already had a tune up and inspection from a local shop that fixed every major issue, starter, heating, headlights, etc. But I want to have some basic tools or parts (high temp self sealing tape, duct tape) on board for the trip home just in case. Any recommendations for basic tools/parts to keep in the truck? I'm coming from a Toyota so I know I'll need SAE mostly ,I'm assuming. Also, what's the approximate space both under and behind a standard bench seat? Thanks in advance! Rob |
02-17-2017, 11:25 AM | #2 |
Re: basic tools to keep in truck
You will likely have a mix of metric and sae fasteners. Body tends to metric while the drive train tends to sae. But exceptions are plenty. You may also have some of the torx screws in and around the lights. A quart of oil, transmission fluid and a gallon of water/used coolant just in case. A few spare bulbs for tail/signal lights.
A combo metric/sae 3/8" socket set with extensions and u-joint, an adjustable wrench, basic pliers, a few screwdrivers, hammer, large screwdriver or something to use as a roadside belt tension adjuster. Make sure you have what you need to change a tire. OEM stuff often goes missing. Known good tire pressure gauge. |
02-17-2017, 04:49 PM | #3 | |
This is exactly what I was looking for! Thank you so much for taking the time to provide such a detailed response! Rob Posted via Mobile Device |
02-18-2017, 12:15 PM | #4 | |
motor exploder
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
03-30-2017, 05:00 PM | #5 |
Since the original poster is driving to California ("SF" is San Francisco right), we can probably forget about him bringing a gun, even a shotgun.
Brother, I carry so many tools and spares you probably wouldn't believe it but that's in my car. Our trucks have no space under seat or behind it, not with gas tank back there. I am going to build myself a tool box for my truck bed to give me some gear space. |
03-30-2017, 07:11 PM | #6 | |
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
04-02-2017, 04:53 PM | #7 |
Thanks for all the replies. My wife and I flew to SF and the very first night the headlights didn't work so we got new lights and I was able to zip tie one of the leads to have them stay put. The PO put some dumb none proper lights in it.
I did have a bunch of tools and supplies and luckily did not need them. Now I can see how much tools and spare parts I can stuff under the bench seat! Rob |
04-02-2017, 08:55 PM | #8 |
Hey Rob, I know your back or on your way back home. Just thought I'd chime in with what we carry:
A couple of cans of "fix-a-flat", an air compressor that runs of the cigarette lighter, and a tire repair kit that we got from O'rielly's, this particular one to be exact. I also keep a small floor jack so should I have a need for a jack. It's a lot better than a bottle jack or scissor jacks IMHO. All the best.
Our very slow build page: http://67-72chevytrucks.com/vboard/s...d.php?t=618078 1981 C20 350ci TH350 LWB Edelbrock Carb |
