Old 10-15-2003, 09:50 PM   #1
Nate003
swapping leafs out for coil rear end
hey guys, i'm looking to get a totally rust free 72 shortbed, only problem is, i want the coil spring rear setup, not the leaf spring. so i have a few questions. can i just swap everything over? I don't have the trucks here to look at the differances, and the second question is, is the long bed coil rear the same as the shortbed coil rear? because i was going to put a coil setup out of a 67 long bed. any help or advice would be great. thanks
oh yeah, and just to clarify, i'm talking about the ladder bars and the springs and the crossmember and everything, not just the axle.
Nate003 is offline   Reply With Quote
Old 10-16-2003, 07:27 PM   #2
Nate003
ttt
Old 10-16-2003, 07:49 PM   #3
72MARIO
72MARIO's Avatar
Yes, Yes, and Yes just drill out the rivet's and get Grade 8 bolts you are done.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-17-2003, 02:38 AM   #4
FRANKIEPOTATAS
I'm not entirely sure but the rear axles may be different lengths. At least check the lengths of the leaf axle and coil axle before you start.
FRANKIEPOTATAS is offline   Reply With Quote
Old 10-17-2003, 10:27 AM   #5
rambler
MOVE OVER
rambler's Avatar
The axles are different lengths, the 71-72 are a little wider, also you are now going from a 5 lug to a 6 lug, I would look for a 71-72 coil for the swap if possilble.
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
